dana 44 gears.
Discussion in 'The Garage' started by chulisohombre, Jun 20, 2003.
  1. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    are all dana 44 gears the same?i know that you cant use ford high pinion gears,but other than that i just want to make sure.i can buy gears out of a dodge 44 for a good price.i just want to be sure that they will work.thanx in advance
  2. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    Yes, but there are some exceptions
    like you mentioned reverse cut,, and corvette
    good luck
  3. chulisohombre
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    ttt anybody know the answer.i gotta get these gears changed so i have 4 wheel drive again
  4. chulisohombre
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    i still need some answers.anyone??????
  5. chulisohombre
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    how many splines do 72 blazers axle shaft have?are all dana 44 axleshafts the same for blazers?also i found a cheap dana 44 gearset out of a dodge.will this work for our trucks?is the spline count the same for their sidegears?
  6. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    K5s use a 30 spline shaft. What does that have to do w/ the gear? Ex answered your gear "?". Do you have a more spefic(sp) one? If you mean are the '72 down and 73 up the same or are the 3/4 & 1/2 ton the same shaft length, then yes. www.warn.com for axle shaft "?"
  7. chulisohombre
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    when i change the gears i needed a new case so im going to take the case and the gears from the dodge.but i needed to know if the spline count was the same for the side gears and axleshafts to work.thanx for the reply.i talked to the gear shop and they said they are the same,so i now have my gears shipped.i just hope install goes good.this will be my first time.
