Dana 44 HD, does anybody know about these?
Discussion in 'The Garage' started by OrangeCrushK10, Oct 13, 2004.
  1. OrangeCrushK10
    OrangeCrushK10 1/2 ton status
    Jan 25, 2003
    1,425
    Square State + Suspension Item
    It's an 8-lug front end off of a chevy. It has external hubs (I am assuming from the studs sticking out where the hubs should be) and I've been told it's a Dana 44.
    Now, I'd believe it's a D44 as it looks about the same size as my 10-bolt, but in all the pictures of the 8-lug D44 I can find they all have internal hubs! /forums/images/graemlins/confused.gif
    Can somebody help me out here and just give me some general info?
    Thanks!
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
    Older model D44's had the external hubs. I believe it is 1973 and older. This axle should also have the small axleshaft u-joint that a newer D44 and Corp 10bolt.
  3. nvrenuf
    Jan 7, 2002
    13,076
    246
    Mobile, Al.
    Early 3/4 ton D44HD's had the external hubs (76 and older, I believe). Their are some wheel bearing and axle tube size differences but for the most part it's the same as any other D44. They use the same carrier/r&p combo and axle shafts as the later 1/2 or 3/4 ton D44's.
  4. jwduke
    jwduke 1/2 ton status
    Aug 25, 2001
    721
    Ice Cream Capital of the World, IA.
    I think the tubes are thicker, but they have smaller-weaker bearings than later D44's
  5. bigblock44k5
    bigblock44k5 1/2 ton status
    Jun 8, 2003
    396
    Hurlburt Field, FL
    The wheel bearing locks are different as well. HD's use the 2 jamnuts with the holed spacer between, whereas regular 44's come with jamnuts that have teeth that interlock eachother.
