Dana 44 help please
Discussion in 'The Garage' started by Gmck2500mudder, Dec 20, 2006.
  1. Gmck2500mudder
    Gmck2500mudder Registered Member
    Jul 21, 2006
    31
    Canada
    Hi, the front end in my 1980 k20 is totally fubard. I have anther dana 44 to put into it but the one the is still in the truck in an eight lug and the one i want to put in is only six. Can i swap the hubs? Also, I want to match the gears to the rear end. The rear end is 4:56 and the new front end is only 3:73. So what do i need to buy? A new gear set? any help would be great. Thanks. Clayton
  2. krechj
    krechj Registered Member
    Nov 14, 2005
    33
    Murderapolis, mn
    your dana hubs will interchange fine and for matching the gears your gonna need a new carrier and gear set for your front
  3. Gmck2500mudder
    Jul 21, 2006
    31
    Canada
  4. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,995
    134
    You want to get a set of 4.56 "thick" gears. This will allow you to use your current carrier. If you don't know how to setup gears, pay someone to set it up or read here:
    http://www.pirate4x4.com/articles/tech/billavista/Gear_Setup
    Your axle should have 30 spline inner shafts and 19 spline outers.
  5. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    Why don't you just take the gears out of you fubard D44 and swap them into your new one? Strip the 8 lug stuff off and put it on the 6 lug. Use the spindles out to the hub. The bearing diameter is larger on the spindle for the 8 lug 44's.
    BTW, what is fubard on your existing 44?
