dana 44 help!!!!!!!
Discussion in 'The Garage' started by 74beater, Aug 26, 2003.
  1. 74beater
    74beater 1/2 ton status
    Sep 20, 2002
    242
    ELGIN ,TX
    how do i get the d*mn bearings out..it is a 74 dana 44..
    use to be fulltime, but the preivous owner converted the hubs..
    please advise
  2. 77Jimmy
    77Jimmy 1/2 ton status
    Sep 3, 2002
    661
    Atlanta, GA
    This might help... /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
    bearing replacement
    I just got done replacing the bearings and races in my D44 w/ manual Warn hubs. Let me know if I can help! /forums/images/graemlins/thumb.gif
  3. pismorat
    pismorat 1/2 ton status
    Oct 29, 2002
    540
    California
    Here's how mine go:
    - take manual hub off
    - remove two clips (one around spindle, one inside hub)
    - slid the guts out
    - take out locking nut w/ special socket
    - take out thrust/locking washer
    - remove tightening nut w/ same socket
    - take outter bearing out
    - take off calipers and remove disc/hub assembly
    - remove inner seal and pull that bearing out
    Hope this helps. I do mine enough so I should know. /forums/images/graemlins/truck.gif
  4. 74beater
    Sep 20, 2002
    242
    ELGIN ,TX
    I CAN NOT GET THE GUTS TO COME OUT...I CAN GET THE LITTLE SNAP RING OUT AND THE BIG ONE AROUND THE OUTSIDE OF THE HUB...BUT I CANT GET THE GUTS OUT
    PLEASE ADVISE...TOOLS OR TRICKS
  5. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    If you've got internal hubs, thread two or more of the long bolts (that hold the shiny cover on) into the "guts" and use them as a handle to pull.
