Dana 44 Internal-VS-External hub
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by backwood heavy, Sep 30, 2002.
  1. backwood heavy
    backwood heavy Registered Member
    Apr 3, 2002
    12
    Passaic cty, NJ
    I am looking at a 91 blazer with a set of 3/4 tons with 4.10's, a 14b FF and a Dana 44 with the large external hub. I think I remember this being weaker than the internal new style hub. I also wanted to know when they stopped using this style hub so I can put a date to the set of axles and maybe know how much mileage they have seen.
    Thanks in advance and I hope I can get a truck soon stinking honda /forums/images/icons/tongue.gif
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    The last year of the external hubs was '76. These are the "first design" parts. /forums/images/icons/wink.gif
  3. Kyle89K5
    Kyle89K5 1/2 ton status
    2,273
    OKLAHOMA
    In all honesty, there is nothing wrong with the larger external style hub. Warn makes a premium hub for them as does several other companies. I've been running a set for a while now on mine and haven't had problems. External style hubs got a bad rap from the Jeep crowd. Lots of problems with them loosening up and whatnot. Hasn't been an issue with mine. On a strength note, I've got a feeling it's gonna be pretty hard for me to break 6, 1/2" or so bolts that thread into the bearing hub.
    As far as Dating the axles, they aren't 30 years old yet, but they are getting dang close....
  4. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    They could be over 31 years old as they started using those front hubs in '71 on the K20s. /forums/images/icons/grin.gif
  5. backwood heavy
    Apr 3, 2002
    12
    Passaic cty, NJ
    It has the Warn Lockouts with the new conical warn base so It should hold out I was just curious. And if i ever felt like it i could find a 3/4 ton Dana 44 internal hub under any rock or stump. OK, gonna go call they guy hope hes home.
  6. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    If I am not mistaken, 3/4 ton hubs all are external, the 1/2 tons had them external then switched to internal.
    I could be wrong though.
    IceMan
  7. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    The 71-up 1/2 tons were all internal....
    The 71-76 3/4 tons were external....
    Everything was internal from 77-up on straight axle trucks
  8. thatK30guy
    Jan 12, 2001
    32,076
    55
    What beast388 said.../forums/images/icons/wink.gif
  9. ken
    ken 1/2 ton status
    1,244
    Anaheim, CA
    Wrong again Garlic Breath!!! (J/K!!!) The large style external hub was used in GM 4x4s since they started putting Dana 44s under 3/4 tons in 1960!! And used all the way up until mid-1977, that's right, MID-1977. It was the "first design" hub for '77, after which they went to the internal hub like the 1/2 tonners had all along. I've heard that the externals are weaker, but the external factory Spicer hubs are STEEL, compared to the aftermarket internal hubs which are cast ALUMINUM!! I don't know bout you guys, but I've allus thought that steel was stronger than aluminum! Oh well, I don't worry bout that anymore, as all three of my rigs are equipped with 60 fronts !! /forums/images/graemlins/wink.gif /forums/images/graemlins/burb.gif /forums/images/graemlins/truck.gif
  10. thatK30guy
    Jan 12, 2001
    32,076
    55
    Hey Dildo Breath! /forums/images/graemlins/wink.gif /forums/images/graemlins/laugh.gif (Just kidding! /forums/images/graemlins/wink.gif) You are right on all counts with the years, but I was sticking with the '73-'91 years instead. /forums/images/graemlins/wink.gif
  11. ken
    ken 1/2 ton status
    1,244
    Anaheim, CA
    Are you denying an old man his opportunity to recant ancient history?!?!? /forums/images/graemlins/thumb.gif /forums/images/graemlins/burb.gif
  12. thatK30guy
    Jan 12, 2001
    32,076
    55
    LMAO!! /forums/images/graemlins/laugh.gif
