dana 44 knuckle steering arm, i cant get that F#%$ing thing off
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 4x4 Cowboy, Mar 5, 2003.
  1. 4x4 Cowboy
    4x4 Cowboy 1/2 ton status
    Dec 7, 2002
    236
    california
    i have d44 knuckles for my 10 bolt to do crossover steering. but i cant get the dam steering arm off. i got the three bolts off which took me like 1 hour.but the arm wont come off /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif i used a blow torch, hammer(oops), big hammer saw. that little f er wont come off /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif
    please help before i break it. sorry need to blow steem
  2. tRustyK5
    Jul 23, 2000
    36,173
    1,385
    E-town baby!
    Hit down and side to side. Do not hit from below the arm upwards. There are cone washers that you need to pick out as they break loose. I got one off a really crusty 10 bolt in less than 10 minutes...5 good smacks side to side and one washer loosened just enough to be able to pick it out...another couple of smacks and the other two loosened up. Once the washers are out the rest is cake. I used a sharp pick and some needle nose pliers to remove the washers when they loosened a bit.
    Rene
  3. bad_bo_ti
    bad_bo_ti 1/2 ton status
    1,027
    OhiO
    one thing i started doing on mine is, if you have access to a welder, put the nuts back on and weld them on to make a bolt then whip out the impact and go to town.
  4. TorkDSR
    TorkDSR 1/2 ton status
    Sep 1, 2001
    1,258
    bucks co pa
    get a bigger hammer and hope that the neighbors sleep soundly. we lost my favorite sledge to steering arm... a moment of silence please
  5. Catman
    Catman Registered Member
    Feb 4, 2003
    53
    Yucca Valley, Calif.
    Been there, broke that. I used an air chisel to pry it off. Good thing 'cause the next step was C4! /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif
  6. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    I beat on mine w/ a splitting mall until the cones loosened up, then I pulled them out w/ pliers.
  7. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    I pounded on mine for a long time, and nothing budged so I got the air chisel and started to hit on it and it turned, so I kept turning it and it went up.
    It seems the cones were crushed on the studs so much they developed threads.
    so on the 2 left I strted that way, and it worked.
    I had to replace the first one that I mangled with the air chisel.
