Dana 44 knuckles, need help!
Discussion in 'The Garage' started by TrcksR4ME, Apr 7, 2002.
  1. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    Seattle, WA 98103
    Well I am in the process of swapping out my old dana 44 for a different dana 44. My original dana 44 from under my truck is complete and the new one is just the housing and gears.
    So what I want to do is take the knuckles from my old one and install them on the new housing. The problem is what do i do about the adjusting sleeve? I am not installing new ball joints at this time and the Haynes book says not to re-adjust these unless you are installing new ball joints. So how do I know if it is adjusted right when I put the knuckles on from a different axle?
    Also i says to replace the self locking nut on the lower ball-joint. I have looked and so far can't find just this part. Will a nut and lock-tite do the same thing?
  2. 4X4HIGH
    Dec 14, 2001
    Pleasanton, CA.
    You can purchace the spanner socket for the adjusting sleeve from most parts stores or tool trucks for around $15.00. As far as the lower nut is concerned, i would just reuse it if you can't find it anywhere and use a little lock-tite on it. By the way, if i remember correctly the preload on the spanner sleeve is somewhere betwen 60 and 90 ft. lbs. When i did mine i set them at 75 ft. lbs.
