Dana 44 knuckles
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by Chris_T, Dec 3, 2001.
  1. Chris_T
    Chris_T 1/2 ton status
    Mar 17, 2001
    718
    Saskatoon, SK
    I have a military rebuilt chev 8 lug Dana 44 w/ 4.56's sitting in a crate in my backyard. I want to swap the 6 lug stuff over since I want to keep my 12 bolt (4.56 gears sitting in the garage). Is there any benefit to keeping the 72-knuckles? It's stored for the winter, so I haven't looked to see if the passenger side is a flat-top knuckle. Does anyone know if it is/should be? Since axle in the crate has all new balljoints, bearings, etc. I was going to just do spindles out, but swapping the knuckles would be just about as easy. Ken Brown on Blazernet posted something about bigger spindles and bearings on post-72 Dana 44's. Does anyone have the year that they went bigger?
    Thanks in advance
    CT
  2. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    you can do the swap without removing the spindle. you can use everything from the backing plate out. there is a write up (tech section) on going from 6 to 8 lug you can just reverse the steps and it should work for you. you can also searthc the main board.
    ARQ.
    offroad baja!!!
    72 4x4 CST Blazer
    71 4x4 CST Blazer
    <a target="_blank" href=http://coloradok5.com/gallery/ArqDennis>My Pics</a>
  3. Chris_T
    Mar 17, 2001
    718
    Saskatoon, SK
    Do I use 72 bearings, rotor, etc? or the later, larger ones? If it's a flat top knuckle I'll probably end up swapping it just in case I ever feel the need to do a crossover setup.
  4. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    The 72 uses the smaller u-joints but everything is the same...almost. The seal for the axleshaft is a bit different. When I bought new seals the kit (which comes with the spindle bearing, and some seals) had a conversion piece to make the older axleshaft work with the newer seal. AFAIK everything else is the same.
    '71 Blazer CST w/ a 400sbc, 4" lift, 36" Supper Swampers, and alot of rust
    <a target="_blank" href=http://community.webshots.com/user/triaged>See it Here </a>
  5. Chris_T
    Mar 17, 2001
    718
    Saskatoon, SK
    If I read the 6 to 8 lug conversion article in the tech section correctly, I should be able to use the 3/4 ton spindles only if I use the 1/2 ton stuff from a later-model 44 - anyone know which year the bearings changed? I remember readins somewhere that you can swap the bigger spindles and bearings into the early Dana 44 without a hassle. I'll be using the 'new' axles as well since supposedly all the bearings, u-joints, ball joints, etc had been replaced. Guess I'll have to go visit the Blazer to look at the 72 passenger side knuckle, unless anyone knows if it's flat.
  6. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    My 72 has a flat top on the Pass side...
    <a target="_blank" href=http://coloradok5.com/gallery/Burt4x4>http://coloradok5.com/gallery/Burt4x4</a>
  7. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    thatk30guy knows his stuff! Check out what he has to say in these posts.
    <a target="_blank" href=http://coloradok5.com/forums/showflat.php?Cat=&amp;Board=blazer4x4&amp;Number=267081&amp;page=&amp;view=&amp;sb=&amp;o=&amp;vc=1>post 1</a>
    <a target="_blank" href=http://coloradok5.com/forums/showflat.php?Cat=&amp;Board=blazer4x4&amp;Number=214490&amp;page=&amp;view=&amp;sb=&amp;o=&amp;vc=1>post 2</a>
    <a target="_blank" href=http://coloradok5.com/forums/showflat.php?Cat=&amp;Board=blazer4x4&amp;Number=166710&amp;page=&amp;view=&amp;sb=&amp;o=&amp;vc=1>post 3</a>
  8. Chris_T
    Mar 17, 2001
    718
    Saskatoon, SK
    Very cool, Thanks
  9. clarkekent
    clarkekent Registered Member
    Sep 26, 2000
    69
    NY
    What years had the Flat Top knuckles?
