Dana 44 mounting question
Discussion in 'The Garage' started by BozoWise, May 1, 2002.
  1. BozoWise
    BozoWise 1/2 ton status
    Mar 28, 2002
    1,224
    Lubbock, TX
    Do all front Chevy Dana 44 have 4 ubolts? Or does some of the D 44 have the 3 u bolt setup with the 2 mounting studs on the pass side.
  2. CK5
    May 19, 1999
    21,622
    701
    CO
    Four ubolts for the D44 and 10-bolt, the two mounting studs are used on a Dana 60.
  3. BozoWise
    Mar 28, 2002
    1,224
    Lubbock, TX
    That is what I thought, but when I posted that the donor vehicle is a 3/4 ton truck everyone says that is HAS to be a D44 because Chevy did not put D60 in the 3/4 ton. I had never seen a D 44 with 3 u-bolts. I wonder if the fact that the truck is a diesel has anything to do with the D 60 being in a 3/4 ton.
    NOW I have to get the truck so I will have a D 60 and 14 bolt FF unfer the Blazer ;-)
  4. CK5
    May 19, 1999
    21,622
    701
    CO
    Well, my K5 HAS to have a 10-bolt in it because it is a 1/2 ton, but I have a 60 in it because I swapped it in so that could have happened in your case. Also, an easy way to tell D44 from D60 is that the steering arm on a 60 is attached with four studs while the D44/10bolt uses three large studs. Or you can simply wipe the dirt away and either F60 or D44 will be stamped on the front lower part of the pumpkin just to the right of the cover.
  5. gmule
    gmule 1/2 ton status
    Apr 2, 2002
    196
    Conifer Colorado
    That may be a dodge dana 44 they use studs instead of a u bolt on the pass side.
  6. BozoWise
    Mar 28, 2002
    1,224
    Lubbock, TX
    Ok it is a 60 and a 14 bolt. Can I remove the axels from the truck and put them under the blazer and then swap in the 1/2 ton under the truck. I know I will also have to switch u bolts and spring plates. I think from my reading the u joints will be the only thing that I have to replace since the mounting points are different size. What about brake lines? The truck is running so I would like to steal his axels and put mine under it so I can resell the truck ;-)
