dana 44 or is it a 60??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by clintsk5, Jul 18, 2000.
  1. clintsk5
    clintsk5 1/2 ton status
    Mar 2, 2000
    288
    Kingman, Az.
    Ok...here's the deal ...a friend of mine owns a salvage yard and he is willing to trade in my crappy 12 and 10 bolt axles for a 14 bolt and a 44 or 60 front in with any gears we can find...all he needs is $350 and my axles..ok heres the question....is there a sure way to tell the 44 and 60 apart without tearing it apart?...I found a frame with a 14 bolt and a 44 or 60 with 4:10 gears still bolted in and ready to go!..I took the axle comparison from this sight with me but still had promblems.....any help would be appreciated...thanx!
  2. Moose
    Moose 1/2 ton status
    1,062
    Glendale, Arizona
    probably the easyiest way is to look at the ball joint area. If you look over the tire down to the axle a 44 has 3 large bolts in a spead u shape and a 60 has 4 bolt in a square pattern. Hope it helps.
  3. clintsk5
    Mar 2, 2000
    288
    Kingman, Az.
    sure does help...thanx!
  4. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>Also, a Dana 60 has larger locking hubs than a 44 or 10 bolt. It will say "60" on the centersection somewhere too</font color=blue>
    http://www.chrisd71k5.coloradok5.com <font color=blue>Updated!</font color=blue>
  5. CK5
    May 19, 1999
    21,622
    701
    CO
    Thats an easy one, they will have either a D44 or a D60 stamped on the case just to the right side of the diff cover (looking at the axle from the front). You may have to remove some grease to find it, also the hubs on the D60 are huge compaired to the D44.
    Steve
