dana 44 question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by PineyPower, Feb 26, 2003.
  1. PineyPower
    PineyPower Registered Member
    Jan 16, 2001
    52
    New Jeresy out in the pine barrens
    ok i had a ten bolt up front and got a danna 44 from one of my buddys.Well the danna 44 had the gears to match my back rear so i was just going to gut the 44 and swap the gaers and axels.Well when i did i found out that the gears would not just slide in like i had hoped.So now I am stuck between a rock and a hard spot.I yanked the 10 bolt out and started to bolt the 44 up under the truck and found out that where the steering arm mounts up to the knuckle there is 3in block (what is this and do i need to use it.the 10bolt didn`t have this.)So i tried to take it off broke 2 big ass pry bars a 1 screw driver so far.Can i just take the spindel off the 10 bolt and put in on the 44??? Will that work and can i use my rotors from the 10 bolt on the 44?? Man i wish the gears woul have just slid into the 10 bolt housing..help please
  2. 4x4Freak
    4x4Freak 1/2 ton status
    Apr 21, 2002
    792
    Lubbock, TX
    The block is to raise the steering arm on a lifted truck. I believe that everything from the knuckles out will swap between a 10 blt and D44. You might try doin a search, I know this has been covered before.
  3. PineyPower
    Jan 16, 2001
    52
    ok thaNKS
  4. backyardbuilt
    backyardbuilt 1/2 ton status
    May 28, 2002
    1,301
    Olathe, Kansas
    Everything from the knuckles out can be switched just not mixed and matched (spindles changed sizes at some point) the rotors will interchange.
