Dana 44 rear or original 10 bolt?
Discussion in 'The Garage' started by dvani, Oct 30, 2005.
  1. dvani
    dvani Registered Member
    Apr 6, 2004
    48
    Boise, Idaho
    Have a '90 FS Jimmy that im gettin some pinion bearing noise from the rear end. Had my axle shafts replaced last year with stock shafts and now this. Is it worth upgrading to a 44?
    I don't do any heavy wheeling and its my dd. Any input would be appreciated.
  2. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    cheaper and easier to find another 10 bolt that will bolt right in. Dana 44s were never offered under the rear of a fullsize truck.
  3. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    a 12 bolt would be a better way to go, but 10 bolts are esy to find. 44's arnt that much stronger than a 10 bolt (if any) anyways...
  4. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    what 12 bolts have in ring and pinion strength over a 10 bolt is lost due to smaller pinion bearings.
  5. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    14 bolt.
  6. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    Rockwell :D
  7. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    try a 14b sf. 9.5 ring gear over the 10b's 8.5 ring gear, can get 6 lug too
  8. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    Where are you located? I have the 10 bolt out of mine sitting in San Antonio that needs to be taken...
  9. dvani
    Apr 6, 2004
    48
    Boise, Idaho
    I am in Northern Utah... I still need to find out what my ratios are yet.
