Dana 44 rebuild info/help needed
Discussion in 'The Garage' started by 80blackgmc, Nov 21, 2004.
  1. 80blackgmc
    80blackgmc Registered Member
    Nov 21, 2004
    43
    Hey guys, well since I can't find a Dana 60 I need to rebuild my Dana 44. So far I got Motive 4.56 gears, bearing kit, axel seals, new wheel u-joints and new Warn Hubs. I am still using the stock used axels, and the long drivers side axels is what I have broken in the past. Does anyone make good aftermarket axels, or should I just rebuild it using stock Dana 44 parts and wait until I find a Dana 60?
    The truck is an '80 GMC with a sm465, 4.56 gears, 35" tires, 355 inch stock motor, 205 transfer case, 14 bolt in the rear.
    Anyone have any links on what is all required to fit a dodge Dana60 into this truck? Thanks guys.
  2. kyser_soze
    kyser_soze 1/2 ton status
    Sep 4, 2004
    3,180
    KC Missouri
    Petersons 4 wheel and off-road magazine had an article in june about the very same topic called the big gun 44-35 put a search on google and check it out. /forums/images/graemlins/pimp1.gif
  3. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    I am running chrom-molys and a ctm on the long side and an ox u joint on the short side w/ 35's. I feel a little more confident in my drivetrain. I am still pretty easy on it though.
    Here is a good read on the subject Click here
    IMO if you aren't going bigger than 35's you shouldn't get a D60. Unless of course you have the dough, then by all means go for it.
