Dana 44 Repair not sucessfull?
Discussion in 'The Garage' started by blopez, Feb 17, 2006.
  1. blopez
    blopez Registered Member
    Jul 25, 2005
    35
    Dana Point, CA
    I was having some seirous wheel movement (up down and Toe). I jacked up the truck and on the driver side hub assebly I had play. So, I replaced the berrings, races, and seal. When I put it all back togather no play. I drove the vehical around the block and it as if nothing changed.
    (1) what did I do wrong?
    (2) What is the problem?
    (3) What sould I do Next?
    1972 GMC Jimmy. Dana 44 (5F) with an 8 lug roter assembely. 39.5 in Super swampers.
    TIE ROD ENDS?
  2. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I would say balljoints.
    Ira
  3. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Answer = IRA x2
  4. blopez
    Jul 25, 2005
    35
    Dana Point, CA
    Ira?
    Whats IRA?
  5. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    ira, the first guy that responded.
    i say balljoints also.
  6. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    Ball joints or TREs.
  7. readymix
    May 30, 2004
    6,706
    26
    I am hurting now.....Dr. Pepper exiting through the nose.....
  8. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I agree with the balljoints being the problem. I would have to say that the 39.5's don't help your cause any either. When you replace the balljoints make sure you use good quality parts and make sure that they have a lifetime warranty. With 39.5's you will be replacing them again. What wheel backspacing are you using?
    The taller and heavier the tires are the more leverage they have on the balljoints. The larger the tires and the harder you wheel the harder it is one the ball joints. Less backspacing is harder on balljoints.
    Friends of mine that wheeled hard with 35-37" tires on D44's with low backspacing wheels would wear out balljoints in 3-4 months of use. They would be out wheeling at least 2 weekends a month though.
    Harley
