dana 44 schematics
Discussion in 'The Garage' started by chulisohombre, May 31, 2002.
  1. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,140
    14
    Bangor,Pa
    any body know where to get dana 44 front axle schematics
  2. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    what for ? <no offense intended>
  3. chulisohombre
    Apr 11, 2002
    4,140
    14
    Bangor,Pa
    im trying to see where the axle tube seal goes on a 72 front dana44 axle.mines leaking 80/90 weight and the seal i got looks more of an internal than external seal.
  4. greatwhitenorth
    greatwhitenorth 1/2 ton status
    Mar 10, 2002
    102
    Surrey, BC
    I believe the seal is by the pumpkin, outside the carrier bearings..
    Correct me if I'm wrong, but I think you need to pull the ring gear and carrier to change em.
  5. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Hmmm.......I'm pretty sure there is no seal in there....The tubes are pressed into the housing. If it's leaking from around were the tube meets the housing, chances are the tube is either pulling out of the housing or the housing is cracked. I have first hand experience with this on my rear 12 bolt. Click the link in my sig then go to the "Broken Blazer Parts" album to see my crackd housing,
  6. greatwhitenorth
    Mar 10, 2002
    102
    Surrey, BC
    Where's the oil leaking from?
    The ends of the axle tubes or where the tube meets the diff housing?
  7. bigjbear
    Feb 18, 2000
    13,970
    449
    Marietta GA
    Seal goes in from the inside of the pumkin. There is no seal at the outboard end of the tube on the front axle.
  8. greatwhitenorth
    Mar 10, 2002
    102
    Surrey, BC
    There we go, bigjbear hit the nail on the head.
  9. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The seal is indeed inside the diff housing. To change it, you have to take the entire front end apart, pull the axle shafts and then drop the diff out of the housing. Then you can finally get to the seals to change them. /forums/images/icons/mad.gif Might as well do both sides while you have it ripped apart. Also clean out the axle tubes while you have everything apart. Mud can get up into the tubes and cause those seals to fail. /forums/images/icons/frown.gif
  10. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Hmmm...lol, I guess I shouyldn't assume the D44's are the same as the 12 bolts....duh. /forums/images/icons/smile.gif
  11. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    The Dana 44 is the front, steering axle. Lots more stuff going on in there than in a rear end. On most rear axles, the lube goes out to the ends of the tubes, to keep the wheel bearings lubed. But up front the lube stays just in the pumpkin.
  12. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    I am well aware that the D44 is the steering axle. I've just never had one apart. I've had my 12 boilt apart numerous times. There is no such seal in a 12 bolt, and I made the mistake of assuming that there was one in the D44. If I had thought about it before replying, I would have realized this.
  13. 674x4
    674x4 Registered Member
    Jul 30, 2001
    84
    Sour Lake, Texas
    OK know i need a schematic, i bought an install kit with bearing and shims for my 1972- 1/2 ton 44 but i ended up with a 1974- 3/4 ton 44, as far as i know it shouldn't matter. i have the new axle seals in and am ready to put the carrier in but the packet that was labeled carrier shims are to small of a diameter to fit the bearing reise(sp) i need help please. thanks
  14. 674x4
    Jul 30, 2001
    84
    Sour Lake, Texas
    NOBODY!!
  15. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Errr, Well........What exactly do ya need help with?
  16. 674x4
    Jul 30, 2001
    84
    Sour Lake, Texas
    i figured it out, the shims go on the inside of the carrier bearings. this is my first dana axle to tear down so i wasn't sure where the shims went because they didn't look like they would go behind the reise.
    thanks
