Dana 44 Spline?
Discussion in 'The Garage' started by OffRoader93, Aug 3, 2003.
  1. OffRoader93
    OffRoader93 1/2 ton status
    Nov 30, 2002
    262
    I was wondering what is the most common spline number on a Dana 44 in a 81 3/4 ton Chevy truck???
  2. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,140
    14
    Bangor,Pa
    i think all dana 44s in chevys were 30 spline inner axles.fords and jeeps had 19 spline.im not sure about the outer shaft.
  3. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    1981 would be a 10 bolt and not a D44 axle. In 1981 the axle would be a 28 spline inner.
  4. chulisohombre
    Apr 11, 2002
    4,140
    14
    Bangor,Pa
    actually ive heard of trucks having dana 44's in them into the 80's.someone said they used them in 3/4 tons into the mid 80's.maybe im wrong but i know i heard it on this site.either way a dana 44 could have been swapped in very easily if the truck originally came with a 10 bolt.off roader81 make sure you have a dana 44 and then repost.a 10 bolt will be circular in shape a dana 44 will be oblonged to one side.
  5. OffRoader93
    Nov 30, 2002
    262
    I know its a Dana 44...
  6. bigjbear
    Feb 18, 2000
    13,970
    449
    Marietta GA
    then its 30 spline at the diff and 19 spline at the hub.
