dana 44 swap question
Discussion in 'The Garage' started by wraenking, Jan 24, 2005.
  1. wraenking
    wraenking 1/2 ton status
    Apr 30, 2003
    1,493
    Toms River, NJ
    i just went to attatch the stock axle shaft with u joint to the dana 44 , and the c clips that the bolts go through to mount to the yolk dont fit
    do i need new ones, or do i bend the old ones.
    also, do i need a different u joint like the 14 bolt?
    when i got the dana 44 , it didnt come with the pieces that the bolts go through.
    thanks
  2. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    One may use straps and the other use u-bolts. My D44 uses u-bolts, the holes in the yoke are not threaded.
  3. wraenking
    Apr 30, 2003
    1,493
    Toms River, NJ
    ahh. are the u bolts something i can get from napa?
  4. divorced
    Jul 20, 2004
    5,115
    Yes, that's where I got mine. It may work if you have them look up the parts for a 1976 K20 or something like that since that is what the axles came stock in.
  5. divorced
    Jul 20, 2004
    5,115
    Maybe check your yoke to be sure the holes aren't threaded like the 10 bolt was before you go buy the ubolts.
