Dana 44 Swapibility?????????
Discussion in 'The Garage' started by Bubba Ray Boudreaux, Sep 27, 2003.
  1. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
    So let's say someone wanted to turn a straight axle D44 into a 5 lug unit, would a person be able to use parts off of a D44 TTB unit?
    And last, but not least, what parts are needed? Everything from the spindles on out?
    Thank you.......
    DISCLAIMER: Don't ask why cause I ain't telling, just wanting to expand my knowledge..............
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Honestly, I don't KNOW For a fact, I I'm pretty sure that the knucles are similar enough that it could be done. I'd definitely give it a try. You'd certainly need the backing plates and hub/rotor assembly. You might need spindles too if the wheel bearings are different sizes. I have had one apart but I just can't remember one way or another.
    My friend's '79 F150 is 5 lug though, 5 on 5.5". You could always use parts from something like that to make it 5 lug too.
  3. o2bjimmy
    o2bjimmy 1/2 ton status
    Jun 19, 2003
    307
    Rapid City, SD
    But why /forums/images/graemlins/confused.gif............ /forums/images/graemlins/rotfl.gif
  4. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    It's all a part of "Bubba's BigA** Budget Buildup Blockbuster." /forums/images/graemlins/rotfl.gif
    I'll leave ya with a hint. I am converting the rear end to 5 lug. /forums/images/graemlins/rotfl.gif
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    5 lug Chevy or 5 lug ford? Chevy 2wds are 5 on 5", Ford 1/2 tons are 5 on 5.5". Have you overlooked this, or are you planning on running a 9" in the rear or something?
  6. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    why not just put a TTB in the front end and call it done, 15" of stock travel isnt something to scoff at and much more is available with coilovers and longer radius arms... /forums/images/graemlins/grin.gif
  7. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    Hmmm, I would have to say that with the 9" sitting in the bed of my truck would be the give away. /forums/images/graemlins/wink.gif
    Well, that would be cool and I could have a great deal on the TTB, but with that swap comes the pains ($$$$$) of custom fabrication and I would have to get a transfer case since Ford is driver's side drop and I already have my transfer case of the future and it's for passenger side drop.
  8. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    I have sold early hubs,spindles, and backing plates to ford guy to put disc's on ther old drum bronco's. The 73-75 1/2ton axels use a different sized wheel bearing. unless you have early spindles, you would need them along with the ford rotors. your locking hubs would be the same.
  9. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    Early Broncos didn't have TTB..........
  10. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    Why not get the shafts redrilled for 6 on 5.5?
  11. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    That would probably be the easiest, but down the road I'm gonna FF this 9" and I"m gonna go the high buck route instead of the low buck route like I was going to do and go 6 lug, and I think the best reason is because I want to mindfawk people with a 5-lug 4x4 Chevy. /forums/images/graemlins/thumb.gif
  12. COCHEV
    COCHEV 1/2 ton status
    Jul 9, 2002
    4,055
    Washougal WA
    BRB, you going truck or blazer on this buildup???
  13. zcarczar
    Feb 10, 2002
    2,495
    /forums/images/graemlins/rotfl.gif Try and see if you can get the front rotors and hubs redrilled.
  14. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    The K5.
  15. bablazer73
    Apr 4, 2000
    3,363
    upstate ny
    I know that, But my point was the hubs, bearings and other parts from a bronco d44 will fit a GM d44. If they are the early spindles.
  16. thatK30guy
    Jan 12, 2001
    32,076
    55
    As long as I understand you are going the 5 on 5.5" pattern route, I would only suggest one thing to look for: '78 or '79 F150 4x4 knuckles, caliper mounts, spindles and bearing hubs/rotors.
    Getting this stuff will make the transformation much easier. Ford used 2 different spindles in which the year split was around '76. The newer spindles are held to the knuckles via 5 studs/nuts where the older onle were 6 studs/nuts like the GM axles use. Older axles had drum brakes on the fronts and in '76 they were converted to disc brakes. The bearing sizes are different much like the 1st and 2nd design GM axles.
    Another tip I've heard but never seen nor done would be to get some '78 or '79 F150 4x4 bearing hubs/rotors and slap them onto your current GM axle, BUT..., you would need to find out if the 1st or 2nd design spindle is needed to make the Ford bearing hub fit. This probably sounds easiest to do since you won't have to mess with the knuckles. You can also reuse the GM backing plates and calipers, too.
    PM me if this still sounds confusing. /forums/images/graemlins/thinking.gif /forums/images/graemlins/thinking.gif /forums/images/graemlins/thinking.gif /forums/images/graemlins/thumb.gif
