dana 44 to 10 bolt spring plate?
Discussion in 'The Garage' started by Fry, Oct 26, 2003.
  1. Fry
    Fry 1/2 ton status
    Sep 5, 2002
    400
    Sask, Canada
    I need to know if the spring plate a u-bolts are the same for the 10 bolt as the dana 44?
  2. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    They should be /forums/images/graemlins/thumb.gif
  3. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
  4. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    As long as the D44 isn't an early one with 2.75" axle tubes instead of the later D44/10 bolt 3" axle tubes, they are interchangeable. /forums/images/graemlins/thumb.gif
  5. Fry
    Fry 1/2 ton status
    Sep 5, 2002
    400
    Sask, Canada
    I'm pretty sure that my front axle is the stock 75.
    Thanks for the help guys I really appreciate it. /forums/images/graemlins/thumb.gif
    Beast if you were closer I'd buy you a few beers for all the help you've given me on my 3/4 ton swap.
  6. Fry
    Fry 1/2 ton status
    Sep 5, 2002
    400
    Sask, Canada
    another question, the axle I bought the guy couldn't find one of the axles so he through in another axle but it is a 1/2 ton, am i right in thinking that the 1/2 ton and 3/4 axles are the same? Also I have 4.10 gears from a 85 diff and the 3/4 ton diff I have is a 81 there shouldn't be a problem swaping them in correct?
  7. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Yeah I believe the shafts are the same just different outers. I also believe the gears are the same. /forums/images/graemlins/thumb.gif
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Only thing different is hub/rotor assembly and brake backing plates.
  9. Beast388
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Ah, don't worry about it, my pleasure! /forums/images/graemlins/thumb.gif
    The axle shafts are the same between 1/2 & 3/4 ton axles, as mentioned above. But make sure both shafts use the same u-joint. The pre-'73 axles used a 260x u-joint whereas the '73-up used the 297x u-joint. Also, look at shaft diameter. Here is a thread I made showing some differences that I found between early and late D44's. /forums/images/graemlins/thumb.gif
  10. Fry
    Fry 1/2 ton status
    Sep 5, 2002
    400
    Sask, Canada
    yeah both of the 10bolt shafts look the same side by side, I just want to make sure everythings going to work. I remember reading that some gears if its numerically lower of a gear it won't fit in some numerically higher case for some reason. I think it should go though, the 3/4 tons all only came with certain gears so it should all be the same case.
  11. Beast388
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Since you are talking 10 bolt....Make sure the spline count is the same on the inner end of the shafts. Early 10 bolts had 28 spline and 89-91 (I think) had 30 splines. /forums/images/graemlins/thumb.gif
  12. Fry
    Fry 1/2 ton status
    Sep 5, 2002
    400
    Sask, Canada
    thanks, both diffs & parts I picked up, the 1/2 ton and 3/4 ton are from 81-85. Now i just gotta figure out how it goes together /forums/images/graemlins/rotfl.gif
