Dana 44 U-joint Size?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by inphobic, Sep 25, 2001.
  1. inphobic
    inphobic Newbie
    Sep 25, 2001
    What year did the dana 44 go to the larger joint? I have heard that the older models had a smaller joint. Just wanted to make sure i didn't get one when replacing my axle. Any other things I should look for in a dana 44? The only difference in a 3/4 and 1/2ton is the brakes right? No Joint size difference is there? Thanks, Jake
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
    '73 was the dividing year as far as I have been told.
    Mike
    <font color=green>"My K5 is purdyr than your sister!"</font color=green>
    <a target="_blank" href=http://www.geocities.com/emmettology101>www.geocities.com/emmettology101</a>
  3. inphobic
    inphobic Newbie
    Sep 25, 2001
    Cool thanks! I figured it was an easy question just couldn't find any info on it. I didn't see it listed on the specifications page. Jake
  4. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Yup 73 or higher for the 5-297x ujoint. On both versions of 1/2ton &amp; 3/4ton D44, same joint!
    How to tell? Cap size is the eaisyest. Just measure the dia. of the cap. I don't know the part # of the smaller one...
    <a target="_blank" href=http://www.geocities.com/baja/5099>www.geocities.com/baja/5099</a>
  5. Emmettology 101
    May 9, 2000
    8,126
    FL
    The smaller one is a 173-X I believe....
    Mike
