dana 44
Discussion in 'The Garage' started by alf4444, Jan 14, 2005.
  1. alf4444
    alf4444 1/2 ton status
    Nov 1, 2002
    2,051
    T-ville, ut.
    Looks Like I'm going to need to change out the axle ujoints in my d44 any suggestions of what else I should replace while I'm in there.
  2. blueblaze
    blueblaze 1/2 ton status
    Dec 4, 2001
    274
    Salt Lake City, UT
    Your 6 lug hub assembly/rotor. I know your going to get a 14 bolt sooner or later. I would check seals, bearings, races and hub internals. :thumb:
  3. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Only the common sense stuff really. Check your pads and disks as you pull it apart. Check the calipers for sticking pistons and sliding pins.
    If you fancy a front locker now is the time to do it. A LockRight will drop straight in there while you've got the axles out. (depending on your gear ratio, you may need to take the carrier out and remove the ring gear to get the shaft out).
    If you go that far, do the seals whilst you're in there.
    Before you strip the hubs, spin them and listen for rumbling wheel bearings. Replace if nec., otherwise just grease them up when you stick it back together.
    And last of all......if in doubt, ask on here! Don't screw something up because you weren't sure how to do it but didn't want to ask!
    Good luck.:grin:
  4. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Spindel Bearing is often overlooked in most cases dryed out.
    Good Luck
  5. alf4444
    Nov 1, 2002
    2,051
    T-ville, ut.
    I have a factory service manual around somewhere I'll try and scan a pic and have you guys mark what you think I should change unless someone has a part number list already.
    More info is it has 3.73 hubs are new also. Thanks guys this will be my first axle tear down. But I guess its better to learn in the driveway than on the trail.:D
  6. Goober
    Goober 1/2 ton status
    Apr 26, 2002
    2,222
    Mayberry (Auburn, WA)
  7. blueblaze
    Dec 4, 2001
    274
    Salt Lake City, UT
    I have some extra part's in the garage, spindle's, hub assmble etc. If for some reason you need something. It would be free.:cool1:
  8. alf4444
    Nov 1, 2002
    2,051
    T-ville, ut.
  9. alf4444
    Nov 1, 2002
    2,051
    T-ville, ut.
    SWEET! Sounds like you may have done it before, can I call on ya if I get lost?
  10. blueblaze
    Dec 4, 2001
    274
    Salt Lake City, UT
    Are you doing it tonight? I have a company party at the Sky Box. I could help out tomorrow...
  11. alf4444
    Nov 1, 2002
    2,051
    T-ville, ut.
    I'm going to gather all the parts first probalbly be a couple weeks
  12. blueblaze
    Dec 4, 2001
    274
    Salt Lake City, UT
    Right on... Let me know.:waytogo:
  13. '71k204x4454
    '71k204x4454 Registered Member
    Dec 28, 2004
    60
    Hood River Or
  14. alf4444
    Nov 1, 2002
    2,051
    T-ville, ut.
    [QUOTE='71k204x4454]I found this on here (Sorry I don't remeber who I got it from.) the other day that has some good manuals in it. http://www.corvettemania.com/useful/[/QUOTE]
    SWEET! Nice find! Thanks:D
