dana 44 ?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by im_2gr82h8, Jul 15, 2001.
  1. im_2gr82h8
    im_2gr82h8 Registered Member
    Apr 4, 2001
    91
    federal way, washington
    I have a pre 1977 3/4 ton dana 44 (H.D.?) as my front axle while running 35's. I was wondering if there is really any difference between the pre '77 and after '77 44's? I know the brakes and bearings are different (I used to think it was an '78, oops) but is one stronger than the other. I had a guy at the local 4x4 shop go on and on about how the older dana that I had was much stronger and almost as good as a 60! I always thought a 44 was a 44, was a 44,was a 44, etc. Is he on crack, or is there really that big of a difference.
  2. mpascino
    mpascino 1/2 ton status
    Jan 1, 2001
    557
    Connecticut
    The only differences that I know of is differences in the wheel bearings and spindle sizes. I am not sure of the year. Other than that I am 90% sure they are the same. Under the usual circumstances, the wheel bearings are not what you need to worry about failing unless you have 4 big blocks straped to your hood. The other difference might be older 44's have the steering tie bar on top of the knuckles vs. the bottom, giving you a few more inches of clearance(good advantage if you see some rocks with your truck).
    You call that dirty!?
