DANA 44
Discussion in 'The Garage' started by CHEVY 4WD, Nov 13, 2002.
  1. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    This might be slighly off topic but about what is the going rate for a Dana 44(FRONT)? And is it almost a direct bolt in in place of a 10bolt? And did any 44's or all 44's have locking hubs?
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    In addition to this question, do 1/2 manual hubs from a 10 bolt swap directly into a 3/4 ton (8 lug) dana 44?
    (Chevy 4wd, not trying to steal your post, I'd also like to know the answer to your question but had one of my own that I thought was relevant to the topic at hand)
  3. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    you can usually get one for around $200 or less no not all had locking hubs is this a 8 lug or 6? if your just getting it to be stronger than the 10 bolt its not worth the change they are only slightly stronger and i do mean slightly lol if your going from six to eight lug then id say do it and yes it will bolt right in /forums/images/graemlins/smile.gif
  4. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    the lockouts will interchange from a 1/2 to 3/4 ton
  5. nofeartruckin00
    nofeartruckin00 1/2 ton status
    Oct 5, 2001
    798
    Germantown, Wisconsin
    Not all. Depends on what design the axles were. The year break between first and second design axles escapes me right now ('75?) The first design axles use the huge external style locking hub. So aslong as you don't make a design jump, yes the hubs will crossover between 6 lug 10 bolt and 8 lug D44.
    1/2 ton, 2nd design hubs Hubs swap between 10 bolt and Ford TTB D44
    3/4 ton, 1st design hubs 1st design D44, external locking hub
  6. heavy4x4
    Aug 28, 2002
    3,270
    Thanks for doing the "research" for me.
    I'm thinking that my next major mod is a 14 bolt FF rear, and I figure that getting a 8 lug dana 44 at the same time, with matching gears would be the best way to go. I doubt I'd get anything older than '75 anyway.
  7. nofeartruckin00
    Oct 5, 2001
    798
    Research was all in my head, i went through the same thing when i swapped to 3/4 ton. /forums/images/graemlins/thumb.gif
  8. heavy4x4
    Aug 28, 2002
    3,270
    I meant fishing up the pics for me to see. Thanks.
    Dang, all this talk of h.d. axles makes me anxious. I can't wait 'til the day when I can really mash the gas because the axles won't be the weak link.
