Dana 44??
Discussion in 'The Garage' started by MTBLAZER89, Apr 14, 2003.
  1. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
    Hi all I am working on my 14bff and looking for a front to match. Question is Dana 44 3/4 ton....Is it a direct bolt in? If not what do I have to change?
    Question #2 What do I have to do to convert my 10b front to 8 lugs? Just trying to figure out which way is cheaper and easier. Thanks
    -Brian
  2. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    direct bolt in yes, obviously youll need 8 lug rims.
    to convert your 10 bolt to 8 lug
    youll need brakes, calipers, rotors, hubs, im not sure if youll need spindles or not,
    but i think it would be more cost effective. to find a 8 lug front end, rather then buying the parts to do it.
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    You only "need" the 8 lug backing plate, 8 lug hub, and 8 lug rotor to do the swap. You can reuse the stock caliper, spindle, etc. It would be smart to redo the wheel bearings, races, and pads while it is apart, but you don't "need" to.
  4. MTBLAZER89
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
    I thought hubs were the same.
  5. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    locking hubs are the same, but wheel hubs are not. The wheel hub is the piece that has the wheel bearing races, wheel bearings in it. The wheel studs drive threw the rotor and attach to it.
    my personal opinion on swapping axles or converting is this:
    If you don't have to swap gears in your current axle to get it to match the 14bff and you can find the 8 lug parts for a decent price convert.
    If the gears need to be changed or you can't get parts cheap then swap in the other axle assuming it has the proper gear ratio and is in decent shape.
