Dana 44
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Bigd, Apr 3, 2000.
  1. Bigd
    Bigd 1/2 ton status
    Apr 3, 2000
    399
    Co,Colorado Springs
    I have a 1/2 ton D44.I'm changing the rear to a 14b.I'm wondering what it takes to change the D44 to the 8 lug pattern.Already have to much money in front end to change.Any help would be appreciated.
  2. Rockblazer
    Rockblazer 1/2 ton status
    Feb 18, 2000
    114
    South Dakota
    You will need to find a 3/4 ton front end and swap everything from the knuckles out. It is still a dana 44 but 8 lug. Better yet... find a 60 to swap under there! Or carry 2 spares... Shut up!
    Todd
    85 Diesel
    "You're right... I don't understand that Jeep thing!
  3. Anglewood
    Anglewood Registered Member
    Mar 4, 2000
    5
    California, USA
    If you have the cash, I know you can go to a custom shop and have them do a conversion, Other than that, I am not sure how or what parts to use in this type of swap. maybe you could replace the hubs with pieces from a 3/4 ton D44. I'm sure some of the other guys know a lot more about this stuff.
    Anglewood,
    '78 K5 Cheyenne 4x4, 400ci
    http://members.xoom.com/CBlazer.1/bcbalazerpage.htm
  4. CK5
    May 19, 1999
    21,627
    704
    CO
    Very nice
    I may have to use that pic for a ColoradoK5.com banner!!!
    Steve
  5. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>Anglewood is right, all you need is hubs and rotors. A d60 is way stronger than a 44, but they are expensive. if you can find one cheap, i say get it. otherwise, pick up some 8-lug 3/4 ton hubs and rotors. here's Anglewwod's url for us lazy folks
    http://members.xoom.com/CBlazer.1/bcbalazerpage.htm</font color=blue>
  6. Bigd
    Bigd 1/2 ton status
    Apr 3, 2000
    399
    Co,Colorado Springs
    do you know if the hubs will go on the spindles or do i have to get those to.Are these hard to find items.Thanks guys.
  7. CK5
    May 19, 1999
    21,627
    704
    CO
    I believe the spindles are the same (1/2, 3/4 ton, Dana 44 and 10 bolt), check a salvage yard for a 3/4 ton truck or burban and pull everything from the knuckles back. you might want to grab the spindles (hey, your there) and ask the salvage yard if you can return them without a stocking fee if you do not use them. Or use this trick, your at the yard, you see a Chevy part, but your not to sure if you need the part, but you don't want someone else to grab it for the next couple of days, simply place the parts in the trunk of a Pinto or something, that way if you need the part you can come back and get it. (of course you should return the part to the original truck as soon as you can [​IMG])
    Steve
  8. shaggyk5
    shaggyk5 1/2 ton status
    1,610
    SE pennsylvania
    steve, that's a great idea. Why cant i think of stuff like that?
    shaggyk5
    aint nuthin in the world like a heavy chevy!!
  9. RaisedK5
    RaisedK5 1/2 ton status
    932
    Long Beach, CA
    the later 77-on spindles are all the same, but there are some early model spindles, like i have on my 75 that have a smaller inner bearing, you want the larger one, trust me when i saw the bigger one, i thought damn that is bigger, the calipers are the same, but the backing plates are different on the 3/4 ton to accomodate the bigger rotor, if you get the later internal hub style, your locking hubs will even work on it,
    RaisedK5
    "Friends don't let friends drive Fords"
