Dana 44?????????
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Monster, Jan 5, 2004.
  1. Monster
    Monster Registered Member
    Jun 14, 2002
    68
    New Jersey Warren county
    When I bought my 14boltSF it also came with a Dana 44.
    They were from a 85 K20. Now I thought the Dana 44 was a 10bolt. I found out a couple of days ago its a dana 44.
    Whats the difference they both have 10bolts.
    I some what new to the differential world. /forums/images/graemlins/confused.gif
    86K5,4"sus,2"body,35BFG,300Hp,Hotted700-R4,Flowmasters,D44,14boltSF,4.11gears,18"sub,1200Wamp.
  2. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    One is made by the dana corporation and one is made by GM.
    The 10 bolt has a more rounded diff. There is a few differences but they are very close in strength and popularity. They both have a few weak points and strong points but one is no better than the other really. The one advantage the D44 has is the housing is made from nodular iron and is a little stronger than the grey iron that is ised for a 10B housing. They are interchangeable from the backing plate out.
  3. Monster
    Jun 14, 2002
    68
    Good info.
    The dana 44 is 8-lug my 10bolt is 6-lug. can I still swap parts around????
  4. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    Wierd you got a 44 out of an 85, should have been a 10B. Cool find.
  5. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    Good info.
    yes
  6. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    Thats what I was thinking too.
  7. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    Likely swapped in by the PO /forums/images/graemlins/rolleyes.gif
    Make sure your whichever front you use matches the rear gear ratio.
  8. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    im pretty sure all dana axles have filler plug in the diff cover, so if its got no diff cover plug then its gm axle not dana
    but if its not GM axle then someone put it under there at some point
  9. Monster
    Jun 14, 2002
    68
    It HAS A FILLER PLUG in the front cover.
    Also the axel has spicer engraved on them does that mean anything.????
