Dana 60, 14 Bolt disc, do I need?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BlazerBoy, Apr 19, 2001.
  1. BlazerBoy
    BlazerBoy 1/2 ton status
    639
    Chicago IL.
    I am going to be putting a dana 60 and 14 bolt with rear disc under my truck soon. Do I need the master cylinder, brake booster or the proportioning valve? I still have the donor truck so I can take them. I thinking of getting a new proportioning valve anyways. Thanks
    BlazerBoy
    http://generalblueballs.coloradok5.com
  2. ScoobyDann
    ScoobyDann 1/2 ton status
    Mar 9, 2001
    305
    El Paso, TX (Far West Texas near Las Cruses
    id also like to know, ill be doing this pretty soon
    Not all Rednecks drive ugly trucks---umm, nevermind <A target="_blank" HREF=http://jimjim.coloradok5.com>http://jimjim.coloradok5.com</A>
  3. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    If you do a search, this was discussed at length a short time ago. Some say you need an adjustable prop valve (I'm among them) and others seem to get by with anything from the stock valve, to a Cady valve, to a Camaro valve, to no valve at all. Read through and decide for yourself.
    Bad Dog
    85 K30 CUCV, 350 TBI, TH400, NP205, D60/C14, 4.56 Locked
    Soon: 4" lift, 40" tires, massive cutting, shorter wb and rear overhang.
  4. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>Go to the 1st gen forum and look for a thread by Steve Chin, he has a cool booster/master setup for 4 wheel disks.</font color=blue>
  5. titanic
    titanic 1/2 ton status
    Mar 27, 2000
    498
    north alabama(huntsville)
    I have this setup and I was told by TSM company that if I had tires 36" or larger, I didn't need to change the pro. valve and I believe they were correct. The extra weight of the larger tires keeps the rear brakes from locking up. Steve
  6. 1990K5
    1990K5 1/2 ton status
    Nov 6, 2000
    460
    LITTLETON CO.
    i run 35's w/no valve what so ever to my rear disc--and i have to jump on them really hard to get the rears to lock up
  7. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    I did NOT put on a prop. valve (or remove the residual pressure thing, I forget the name, hold 10# of pressure on the rear brake line instad of a more disc-friendly 2#). I have NOT had any problenms with lock-up.
    I think a prop. valve would nto hurt, since you will need to run new hard lines for disc brakes anyways. Might as well plumb a $40 valve inline. But I didn;t and have not had any problems.
    -- Mike
  8. konajoe
    konajoe 1/2 ton status Premium Member
    Nov 15, 2000
    112
    7
    Massachusetts, U.S.A.
    I'm running the one ton master cylinder & hydroboost setup along with a proportioning valve from a 4-wheel disc equipped P30 series Van.
    konajoe
  9. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Hehe, see what I mean! [​IMG]
    Bad Dog
