Dana 60 & 14 bolt ff pinon torque needed ASAP!!!
Discussion in 'The Garage' started by yunit, Aug 3, 2003.
  1. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    Can anyone tell me what the pinion nut's should be torqued to on a Dana 60 front and a 14 bolt ff rear? I spent most of the day trying to find some thin wall sockets to remove the old nut's & yokes and now I need to know what the nuts should be torqued to.
    /forums/images/graemlins/frown.gif
    And I thought I would have the truck done before the UCP charity ride. /forums/images/graemlins/rolleyes.gif I will be lucky to have it together before memorial day weekend. /forums/images/graemlins/angryfire.gif
  2. Stomper
    Stomper ΜΟΛΩΝ ΛΑΒΕ GMOTM Winner
    May 11, 2002
    3,767
    Iowa
    D60 pinion nut torque is 240 to 300 ft lbs.
  3. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    As I understand you are supposed to mark the shaft then put the new nut on (with Locktite) back where the old nut was that way not to affect pinion preload. I don't believe you should put that much torque on it unless you are installing a new crush sleeve. Hope this helps.
  4. yunit
    Feb 24, 2000
    3,068
    Oakland, NJ
    BTW, these axles have never been used; got them rebuilt a few months ago and I am now replacing the yokes.
  5. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
