Dana 60/ 14 bolt...NEED TO GO NOW!!!!!
Discussion in 'Suspension | Axle' started by 79k20350, Jan 1, 2007.
  1. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    Ok guys... I need to unload my 14 bolt/ dana 60.
    They need to go ASAP!!!! make an offer...
    Heres the spec:
    Dana 60 Drw, 4:10:
    Rebuilt from the ends out. Case/ gears, bearing, seals, etc was checked and look/ function perfect.
    New kingpins buchsings/ springs
    New kingpin bearings (lower)
    New wheel bearings/ races
    New locking hubs (mile markers)
    New rotors
    New spicer life series cold forged u joints
    Brake calipers come with, just missing hardware, they work fine
    Ord crossover arm
    Ord hevy duty tierod
    Brand new drivers side knuckle
    Comes with new u bolts + studs (no plates though)
    Axle has 0 miles on it!
    $1400 obo. I will ship but buyer must set it up. Extra $75 for palletizing and drop off
    14 bolt, 4:10:
    Completly rebuilt
    All new bearings/ seal
    Detroit locker
    Extended stainless brakeline
    No brakes, ready for discs
    Extra set of axles shafts
    $400 obo (same as shipping above)
    $1600 for the combo, if shipped i will only charge once for palletizing them...
    06375 is where shipping would be from. Ive dropped off at overnight trucking and forward air is close to me but ive never used them.
    As stated buyer pays/ sets up shipping.
    I will have pics up in a little bit
    Stock 14 bolt spring plates w/ extra holes (to move axle w/ zero rate) $15 + ride
    Aftermarket dana 60 Spring plates $25 + ride
  2. 79k20350
    Nov 22, 2004
    7,757
    Ct
    stuff needs to go... its all obo
  3. twoslo4five0
    twoslo4five0 3/4 ton status Premium Member GMOTM Winner
    Oct 5, 2006
    6,614
    71
    Living in a dump, VA
    are the new rotors dually rotors or single wheel???
  4. 79k20350
    Nov 22, 2004
    7,757
    Ct
    The rotors in the 60 have surface rust. It looks worse in the pics than it is. A brillo pad would take it right off.
    The rotors are for the dually hubs, but dually rotors are the same as srw rotors, the only differance is the holes are smaller. The holes in a dually rotor can be enlarged to fit a srw hub
  5. 79k20350
    Nov 22, 2004
    7,757
    Ct
  6. 01maroonz71
    01maroonz71 1/2 ton status
    Jan 8, 2007
    1,553
    4
    Palmetto, fl
    wish you lived closer....
  7. stan1688
    stan1688 1/2 ton status
    Sep 13, 2006
    779
    Independence, KS
    Does the 60 have a locker or anything like that?
  8. PsRumors
    PsRumors 1/2 ton status
    Nov 11, 2006
    626
    Cartersville, GA
    What is the measurement on the spring pads? I am wanting both of these for my Suburban. Other than the brakes on the 14 bolt and spring plates for the 60 what is needed?
  9. 79k20350
    Nov 22, 2004
    7,757
    Ct
    The 60 is open.
    Both axles will bolt into any 1/2- 3/4 ton 73-87 truck
  10. 79k20350
    Nov 22, 2004
    7,757
    Ct
    axles are also ready to go. Brakes and spring plates like you said. Other than that they are 100%
  11. PsRumors
    Nov 11, 2006
    626
    Cartersville, GA
    I will check on shipping first thing in the morning and let you know.
  12. PsRumors
    Nov 11, 2006
    626
    Cartersville, GA
    Have you checked your PMs?
  13. bluecollarjock
    bluecollarjock 1/2 ton status
    Nov 19, 2006
    278
    Manhattan Beach, CA
    Im interested if you still got them
  14. 79k20350
    Nov 22, 2004
    7,757
    Ct
    This stuff needs to go before i change my mind again:rolleyes:
  15. 79k20350
    Nov 22, 2004
    7,757
    Ct
    TTT, have to go!!!!
  16. NEK5
    NEK5 3/4 ton status Premium Member
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    Hmm, how far in CT are you...that 14bff is tempting....
  17. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    do you go to the Stafford Springs meet? maybe we could meet there? unless if you want to do it before that. Is it possible to bolt up a 4.56 gear set with an open carrier into this, then put the detroit back in?
  18. 79k20350
    Nov 22, 2004
    7,757
    Ct
    Yep, its possible to swap the carriers and run the 4:56's with the detroit thats in it. I still need to move the perches back, or i could knock 25 bucks off if your rather do it ( i know you have a friend with a welder, its real easy to do)
    Id like to do it asap. I could easily meet you half way, whenever you'd like. Are you free this week or weekend?
  19. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    As of right now, I don`t have all the money..but should within the next week or two. I do have a friend with a welder, yes, but you can do it..
    So, it doesn`t come with any brake parts, or did I read it wrong?
  20. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    does it have just the extended main brake line? does it have the brake lines that go to the drums/calipers, or will I need them? if it does, does it have the same fitting as the calipers?
