dana 60 16 spline?
Discussion in '1973-1991 K5 | Suburban | Truck' started by 76K5, Feb 25, 2003.
  1. 76K5
    76K5 Registered Member
    Jun 23, 2001
    99
    North Carolina
    I recently installed a Dana 60 in my truck. It only has 16 splines, is this diff older than Jesus? I've never seen a 16 spline Dana 60. Anyway we are welding up today. Any tips I might need to know. Thanks for the help. Oh yeah, I'm running 39.5 boggers, do yall think it will hold /forums/images/graemlins/usaflag.gif
  2. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,161
    Sacramento, CA
    Are you sure it's 16 not 19 spline?
  3. One_Ton_k5
    One_Ton_k5 1/2 ton status
    Jan 30, 2003
    168
    St Paul Minnesota USA
    early ford 60's were 16 spline.
    I heard they break. I don't think a 30 spline 60 will hold up to those tires.
    Later.
  4. 76K5
    Jun 23, 2001
    99
    North Carolina
    yeah it is an early ford, it is only 16 spline. We are welding the rear end right now. I guess I will just see what happens? Does anybody know where I can get spare 16 spline shafts. I bet they are hard to find?Thanks!
  5. ZonkRat
    ZonkRat 1/2 ton status
    Jan 16, 2003
    1,003
    Lawrence County Tennessee
    I've got parts left from 1970 eaton rear.It's 16 spline axles are still good.Ran it with 38s till locker broke and couldn't get parts for it.If you can use it I'll be glad to bring it to Tellico in Apr. for a little gas money,I'm not going to use it.I think the OD of axles is 1.5 or 1.6,not shure about length,Just let me know before then. /forums/images/graemlins/thumb.gif
  6. One_Ton_k5
    Jan 30, 2003
    168
    I have a set you can have for the cost of shipping.
    PM me if you want them.
  7. One_Ton_k5
    Jan 30, 2003
    168
  8. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Very common in older stuff. Easy to upgrade to 30-spline... just takes axles and side-gears. No real strength difference as the diameter is the same.
    My buddy snapped a 30-spline shaft in his '79 F250. He gutted a '72 F250 with the same rear. Pulled 4.10's, a Powr-Lok & 16-spline axles, and installed the works in the '79 housing.
  9. 3car
    3car 1/2 ton status
    Dec 16, 2001
    976
    Hernando, Florida
    the diameter is the same,however,on the 16 spline axles the splines are cut deeper,making the shaft weaker at the splines.
  10. Langosta39
    Langosta39 1/2 ton status
    Nov 8, 2002
    156
    Moscow, Idaho
    Or you can drill out your spindles and get some 35 spline shafts for the ultimate in rearend strength. Then I guess your ring and pinion would be the weak point.
    andy
  11. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    72THING used to run a welded and 4.56ed 30 spline D60 in his 72 C10 (yes C10...we hung all the 4wd hardware). He broke 3 0r 4 axleshafts in it. He used to carry a spare at all times. In fact, when he sold it, a spare shaft went with it. I'm not saying I wouldn't run it, but I would absolutely carry a spare shaft (if they are both the same, 2 if they are different) and tools to change it out on the trail. This would include a magnet to fish out metal chips and pieces, hand tools, parts cleaner, SOMETHING TO CATCH OLD GEARS OIL AND TAKE TO HOME, and fresh gear oil. I personally will no longer run a welded diff on anything street driven. I ran a D70 HD with the 1.5" 35 spline shafts and when I broke my second axle shaft, it ruined to spindle. Now I run to oh so common FF14 with a detroit.
