Dana 60 3/4 ton Calipers?
Discussion in 'The Garage' started by TONYP, Jan 15, 2004.
  1. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    Has anyone done the change over from the 1-ton calipers to the 3/4-ton ones?
    I saw some brackets for this and looks to drop some lbs. off the axle... /forums/images/graemlins/ears.gif
  2. thezentree
    thezentree 3/4 ton status
    Sep 19, 2003
    7,198
    NC
    no, but i want your 1-ton calipers if you do /forums/images/graemlins/rotfl.gif
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    FINALLY! Someone to make some brackets for the D60 to fit some 3/4 ton rotors and calipers!! I say "yes!" go for it! I've seen lots of pictures of this setup and it seems very simple to make and work.
    Let me know when you get some brackets made. I want to buy some. /forums/images/graemlins/deal.gif /forums/images/graemlins/thumb.gif
  4. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    seems like a down grade in braking power to me!
  5. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Does that mean that NO grinding would be necessary to use 15" wheels?? /forums/images/graemlins/thinking.gif
  6. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    WMS had a kit, of sorts, that keeps an 8-lug design but uses a 1/2 ton caliper set up and allows 5" of bs on a 15" steelie with no grinding at all. I don't know if they have it still but I am sure there are pics roaming around somewhere.
  7. K5DRAGER
    K5DRAGER 1/2 ton status
    Jul 27, 2001
    1,164
    Momence, IL
    Yep I have. /forums/images/graemlins/thumb.gif [​IMG]
    And yes that means you can fit a 15 inch wheel with NO grinding.
  8. big pappa b
    Jan 3, 2003
    6,328
    Falcon, Colorado
    This is the kit from wagone rmachine
    Kit allows the use of 15" wheels on 1 ton king pin Dana 60 front ends and comes complete with loaded calipers, brackets, and rotors.
    $550.00
    Seems a bit pricey
  9. K5DRAGER
    Jul 27, 2001
    1,164
    Momence, IL
    I bought the brackets from a guy that fabs jeep parts for 150.00 and you all already know how cheep you can get the calipers and rotors.
  10. SCJimmy
    SCJimmy 1/2 ton status
    Mar 7, 2003
    406
    Simpsonville, South Carolina
    OK, I'll ask, are there any more for $150??? /forums/images/graemlins/confused.gif
    TonyP, are you looking for them, or are you offering to make some? /forums/images/graemlins/grin.gif
    I'd like some for $150
    [hijack]TonyP, BTW, the D60 shims were the perfect solution.[end hijack]
    Thanks!
    (And get on those D60 3/4 ton brackets already!! /forums/images/graemlins/thumb.gif)
    Byron
  11. TONYP
    Aug 13, 2002
    2,116
    so cal
    I was surfing the other day and ran across the brackets and wanted to know if they were on anyones truck, I might have a go at them...I'll let you know. /forums/images/graemlins/usaflag.gif
  12. K5DRAGER
    Jul 27, 2001
    1,164
    Momence, IL
    I looked for his web site but it looks like its down. I think it was www.jbs4x4.com
  13. skelly1
    skelly1 1/2 ton status
    Sep 2, 2002
    554
    San Diego, CA
    Hate to beat a dead horse here. If you were to buy this kit, that makes it cool for the front, but how about the rear? Will the 15" wheels fit over the FF big rear drums? There's no way to have a 14BFF rear with 6 lugs right?
  14. Fubeca
    Fubeca 1/2 ton status
    Dec 18, 2002
    2,100
    Denver Area
    15" Steel wheels fit just fine over the big ol' drums. /forums/images/graemlins/grin.gif
    There are 2 ways to have a 6 lug 14B FF its been talked about nearly 4 times in the last 3 weeks. Either adapters or new hubs.
  15. thatK30guy
    Jan 12, 2001
    32,076
    55
    Paging TONYP...paging TONYP... /forums/images/graemlins/waytogo.gif
    Still got plans to make these brackets? I'm still interested... /forums/images/graemlins/thinking.gif /forums/images/graemlins/thinking.gif /forums/images/graemlins/thinking.gif
  16. owen
    owen 1/2 ton status
    Nov 21, 2003
    151
    Brewton AL
    Would I seem stupid if I ask if the brackets used on the 14ff drum to disc swap could be used???
  17. bluejeep
    bluejeep 1/2 ton status
    Jan 9, 2004
    106
    Des Moines, IA
    I have the JB's brackets on my Jeep's HP60 with Chevy 60 outers. They fit pretty well after massaging them with a 2lb hammer, but definitely worth the $130 they cost. They allow you to run the 1/2 and 3/4 ton caliper with the 3/4 ton rotors. Both these calipers are the same for those who did not know.
  18. thatK30guy
    Jan 12, 2001
    32,076
    55
    The bolt pattern is different and the D60 bolt pattern surface is also larger in diameter. /forums/images/graemlins/thinking.gif
  19. leadfoot067
    leadfoot067 1/2 ton status
    May 14, 2001
    1,563
    puyallup, washington
    i have a set of the caliper brackets....mine are completely flat...are the ones in the picture also? i plan on doin the 3/4 ton brake thing on mine,i got my brackets for 100 buks from a local guy i know....he tells me i will need to machine 3/4 of an inch off of the backside of the wheel hub surface to make this work?? is this true? thats whats keeping me from doin this.......although i dont have all the parts together to check all this out yet......
  20. bluejeep
    Jan 9, 2004
    106
    Des Moines, IA
    My JB brackets are offset in, no machine work necessary. Just put the 3/4 ton rotor on the hub and slip it on the axle. I **imagine** the ones in the picture are too, because you can see the bosses in the hub where the lugs go through. These would likely be machined off if you took 3/4" off the back side. Ford D60 hubs are much thinner in this area, and don't have the bosses.
