Dana 60 and 14 bolt
Discussion in 'The Garage' started by ramses, Apr 8, 2005.
  1. ramses
    ramses 1/2 ton status
    Jul 2, 2004
    238
    West Virginia
    I havent got to go look at them yet, but this weekend im gonna go look at a Dana 60 and 14 bolt with 4.10 gears. The guy said he would probly take $200 for both together. That seems like a good price to me, even if theyre not in the greatest shape, am I right? I dont need the 14 bolt because I have one so ill probly sell it as soon as I can to fix whatever needs to be on the Dana 60. What exactly should I look for to see if they are good axles? What are some good signs that would tell me that they are good or might be junk? I especially want to know whether the Dana 60 is good, and I have never really even looked at one up close before so I dont know what to look for being good or bad on it. So what will I need to look for to tell me to buy them or not? And what parts on the Dana 60 should I expect to replace before I put it under my truck? Also, what differences are there in a 60 from a 44 besides the 60 is bigger? Does the 60 have the same steering setup? I know a 60 has kingpins but im not sure what they really do. and when I put the 60 under my truck, will everything bolt right up? Will the drag link go on the same way as the 44? And does a Dana 60 have a steering arm like a 44? I put on a different steering arm with my lift, will I have to do something different on the 60?
  2. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    Just look it over the way you would any axle. Take off the diff cover and make sure the inner is not full of salt water.. :crazy: Check the over-all condition, eyeball the tubes and see if they are bent. The D60 will have 3 U bolts, and on the pass side spring perch, to the inside of the perch, there will be 2 bolts holes for the other side of the spring. I myself am going to replace pretty much all the bearings in mine... basically an overhual or at least a re-fresh, since it's not in yet, and is easier to just do now... and that's for one that was on the road before I got it.
    200 bucks is a freakin steal if it's indeed a D60, and in good condition. Good find. :thumb:
  3. ramses
    Jul 2, 2004
    238
    West Virginia
    So how much do you think it would cost to replace most of the parts that wear out on a 60? And what parts would I be looking at replacing? Also, fogot to ask, are the brakes on a 60 any different from a 44? Are the rotors and calipers different? Because I just put new calipers on my 44 recently and I hoped they wouldnt be different so I could use them.
  4. Eric M.
    Eric M. 1/2 ton status
    Dec 10, 2001
    2,118
    Oakland, CA
    Everything is different from the 44 to the 60. The draglink and steering stabilizer can be reused, nothing else. D60 front axles go for about $1K, used. That axle can be an absolute mess, needing a complete rebuild and you're still getting a steal! I'd say brush up on your D60 identifying and if it is indeed a D60 .... don't ask too many questions, don't waste too much time, hand over the cash and load it up fast!
    Here's a link to D60 info:
    Dana 60 Bible
    Good find.
    Eric M.
  5. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    That is an EXCELLENT price, snatch em up quick!!!!!
  6. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    and if the guy doesn't have and engine hoist to lift it, bring about 6 -8 friends to help you lift it. It's almost 600LBs if the steering stuff is on it :yikes:
  7. Emmettology 101
    May 9, 2000
    8,126
    FL
    To make sure you are getting a 60, make sure the knuckles look like this:
    Top kingpin cap:
    Kingpin cap and whole knuckle pic(note: this is a DRW axle in the pic):
    I've seen alot of people think they have a 60 for sale when it is really a D44.
    I would at least rebuild the knuckles(new kingpin parts) on the axle and brakes. Possibly the wheelbearings and seals also... And might as well put in new u-joints to play it safe..
  8. skelly1
    skelly1 1/2 ton status
    Sep 2, 2002
    554
    San Diego, CA
    Just missed one today in the san diego parts trader for $300. Ironically, I was looking for my own selling axle add, which the trader didn't get in this week like they were supposed to.
  9. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    For $200, with a 14 bolt, it would still be a good deal full of salt water. My $150 Dodge D60 came with about a quart of fresh water inside the carrier :frown1: and it wreaked some havoc, but cheap is cheap.
