dana 60 and 15" wheels = ???
Discussion in 'The Garage' started by sweetk30, Apr 6, 2006.
  1. sweetk30
    Nov 1, 2004
    25,552
    545
    horseheads , ny 14845
    i just got done doing the:grind: grinding :grind: for a dana 60 with 15x10 with 3.5" back spacing. all i can say is wow:eek1: :eek1: . i will just buy the 2.75 backspacing next time if i need to do the 15" thing again:doah: .
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    LOL or go with 16's :thumb:
  3. ProJunkRacing
    ProJunkRacing 1/2 ton status
    Jun 20, 2005
    1,229
    FrankFort IL
    or go dually :)
  4. sweetk30
    Nov 1, 2004
    25,552
    545
    i did the grinding and converted it from a dulley.
  5. ProJunkRacing
    Jun 20, 2005
    1,229
    FrankFort IL
    yeah but if it was stil dually you woulda had no problem lol mine is dually i can take my pads and calipers off with my tires still on lol
  6. screamin seeman
    screamin seeman Registered Member
    Dec 19, 2005
    5
    faribault, MN
    Wrong forum for this, please post in the vendors forum if you want to promote your products.
    Rene
  7. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    When I ran 15's on my my first K5 with a D60 I was running 4 1/8" backspacing. I didn't think the grinding was all that bad but I went with 17's on the next K5.
  8. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    I am getting ready to do this as well. I have 4.25 BS on my wheels. What does everybody think about the conversion kit above? Do you just use 10b/D44 calipers?
  9. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    That is what it looks like. If you get 10 bolt calipers you do not have to get new brake lines as the Dana 60 and 10 bolt calipers both use the same size banjo bolt.:D
    Ira
  10. miniwally
    miniwally 1/2 ton status Premium Member
    Aug 11, 2003
    3,069
    206
    Colorado
    I don't want to bust balls but.
    If your gonna pimp your parts you better get yourself paid up as a vender.
    BTW nice brackets been thinking about that sorta thing for my junk.
    (edited to remove quote and link...Rene)
  11. screamin seeman
    Dec 19, 2005
    5
    faribault, MN
    Sorry, didn't mean to step on ant toe's.
  12. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    yeah those kits make thing nice, but one of the great things about goin with a 60 is the brakes IMO
  13. screamin seeman
    Dec 19, 2005
    5
    faribault, MN
    When used in conjunction with rear disc brakes, The truck will stop better than it ever did from the factory. The other pro is that the front and rear uses the same inexspensive parts.
  14. miniwally
    Aug 11, 2003
    3,069
    206
    Colorado
    Your not stepping on ant toe's :haha:
    Just saw you were new and thought I would help you out before some real a$$ did.
  15. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    well i have 3" bs on my 15's and barely had to grind. im thinkin next time goin with either recentered H1's or H2's next time
  16. screamin seeman
    Dec 19, 2005
    5
    faribault, MN
    Thanks, I appreciate that.
  17. MattK
    Jan 12, 2005
    1,713
    Dallas, TX
    did your project turn out like that? my rears have less grabbing power after the disc swap. 14 bolt drums are powerful mofuggas...until they get muddy.
  18. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    i have seemans caliper brackets and they focken rock.
    and if your rear disks are not stopping you need the correct master cylinder and maybe and adjustable proportioning valve.
    also if you think the there is that much difference in the stopping ablities of a 60 caliper verses and 3/4 caliper in can't tell the difference with mine. i feel you are compromising more by grinding the crap outta yer 60 calipers.
