Dana 60 And Other Stuff Needed
Discussion in 'Parts & Trucks Wanted' started by senciman, Dec 12, 2004.
  1. senciman
    senciman Registered Member
    Sep 30, 2004
    36
    D60 Frt Axle, King Pin, Full Width, High Pinyon
    42x17x15.5 Swampers Or Similar
    Winch-9k And Up
    Hope Someone Out There Can Help Me Out,
    Tony
  2. BurbLover
    BurbLover 1/2 ton status
    Jul 31, 2001
    3,060
    SW Missouri
    Not too familier with this size.
  3. senciman
    Sep 30, 2004
    36
    anything close to it will work, i just have a 17 wheel and i need them roughly 42" tall i dont care about the width as long as its wider than13.5. is that clear enough for ya, or do i need to show you with a tape, i dont live in the magazines so the excact size that the tire builders offer is no concern, 13.5 is a little to narrow and 15.5 is all i really have seen in that height
    so BACK OFF.......
  4. jac6695
    jac6695 1/2 ton status
    May 2, 2002
    1,860
    Christiansburg, VA
    Dude, I think that Mark was trying to help you clarify so that maybe someone can help you out. Maybe you are the one that needs to back off....
  5. nvrenuf
    Jan 7, 2002
    13,079
    247
    Mobile, Al.
    Maybe you should back off and take some time to learn about what you're looking for. You wont get much help on the net with that attitude. :surepal: :shame: :whistle:
  6. senciman
    Sep 30, 2004
    36
    marks an allright guy, maybe you didnt catch the humor in the back off statement, hmm. anyways i had a couple of other posts going and the same kind of remarks on those post by burblover, so i was simply letting him know im not here to be contantly flamed on each and every post i put up, as a matter a fact i told mark in the past i would help him get his new landscape co off the ground and talked him out of being a lawn maintenance guy, so maybe your jumping the gun a little, as far as knowing each and every tire size im to busy running four companies to be reading all the magazines,
    maybe ill clarify for you i need a tire size close to the dims. listed, the wheel has to be a 17" , ok-cool
    tony
  7. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    The whole tire size deal was strange because of the 15.5. Usually the rim size is the last number in the sequence. Example 285/75/16 (16" rim) or 42x15x16.5(16.5" rim)
  8. senciman
    Sep 30, 2004
    36
    ooohhh, i gotcha, my mistake
    today i was searching and they were listed like this14x39.5x15 on the swamper site and i thought that was strange
  9. senciman
    Sep 30, 2004
    36
  10. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    That is a ford front axle. It was only made for two years 78-79. They are rare to find anymore. The 17" wheels will limit you to IROK's for tires if you want something wider than 12" and taller than 38"
    Just a little info.
  11. senciman
    Sep 30, 2004
    36
    not to mention the cost of those bad boys (axles), as far as the tires i may have to change the wheels to accomplish what im trying too, the iroks were on a buggy yesterday and i wasnt impressed but it was wet and a little muddy
    thanks,
    tony
