Dana 60 Brake line Question, Extended not working
Discussion in 'The Garage' started by Mudbug1979, Mar 26, 2006.
  1. Mudbug1979
    Mudbug1979 1/2 ton status
    Aug 4, 2002
    439
    Monroe,North Carolina
    OK, I originally put the Napa extended brake lines on my 10 bolt and have been working fine. Just got done putting in the D60 and at full droop the napa lines are about 5" shy of even coming close to the caliper. Caliper brackets only fit one way so the caliper has to be in the correct position, so I'm stumped. I'm only running 4" springs, 1.5" shackle and with the frame on jack stands and the axle hanging by the springs, they aren't even close. Anyone know which ones to go with now?
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Just go get some extensions. That is what I did. I know I have posted the part numbers here before.
    They will gove you an extra 11 inches
  3. Mudbug1979
    Aug 4, 2002
    439
    found
    I searched your posts and found it. 14 is a lot when I'm only needing like 7 more, course I never would have to worry about them ever being too short again.
  4. sweetk30
    Nov 1, 2004
    25,548
    543
    horseheads , ny 14845
    you could drop the line to a lower point on the frame to help. i took my 83 and cut off line brackets and remounted them to the bump stop spots as i ran 6" lift front. worked great.
