dana 60 brake lines
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by frito, Feb 17, 2002.
  1. frito
    frito Registered Member
    Oct 17, 2001
    60
    fremont, CA
    does anyone on the board with a Dana 60 front in a 1st gen K5 or early 2nd gen or P/U that had a dana 44 stock know where to get brake hoses that will fit our trucks .. with a dana 60 in the front?
    71 K5 Blazer,350/TH350/205 33's/ 2inch lift for now, soon to have 14B FF and D60 in a few weeks
  2. Chaz88K5
    Chaz88K5 1/2 ton status
    2,979
    Stockton/Lodi CA
    i used the hoses for a truck with a 10 bolt front...so if you ask for lines for a 88 blazer it would put ya on the right track.
    <font color=green>Chaz</font color=green>
    [​IMG]<a target="_blank" href=http://community.webshots.com/user/chaz88k5>http://community.webshots.com/user/chaz88k5</a>[​IMG]
  3. frito
    Oct 17, 2001
    60
    fremont, CA
    yeah thats what i was thinking of doing ... the end of the hose that goes to the frame is the same size as the earlier trucks? i was guessing they prolly were but wanted to make sure
  4. 72THING
    72THING 1/2 ton status
    Nov 26, 2001
    501
    Ranburne, AL
    I have '72 pickup with D60 front. The D44 lines will work just the same. I used my old lines from D44 when I switched to D60, but now I am running Explorer Pro Comp extended braided steel brake lines. They gave me the slack I needed at full droop (for a 6" lift). My original lines were so tight at full droop they could be strummed like a guitar. Hope this helps.
    Will
    '72 C10, originally 2WD, 6"Springs f+r, Dana 60 f+r, Lock-Right front, welded rear, 4.56s, 350, SM465, NP205, 39.5" TSLs, ORD crossover steering
  5. Klef72K5
    Klef72K5 1/2 ton status
    Apr 8, 2001
    249
    Columbia City, Indiana
    Did you guys have to change your porportioning valve? I'm planning on switching axles this spring with the 60 model and 14 bolt and was curious.
    <a target="_blank" href=http://wsphotofews.excite.com/031/rw/Jo/og/t488200.jpg>http://wsphotofews.excite.com/031/rw/Jo/og/t488200.jpg</a>
  6. frito
    Oct 17, 2001
    60
    fremont, CA
    no you dont have to change the prop. valve
