dana 60 brakes*updated*
Discussion in 'The Garage' started by Bhintz, Jun 22, 2004.
  1. Bhintz
    Bhintz 1/2 ton status
    Mar 28, 2003
    1,341
    Roswell, Ga
    went to install my dana 60 front and went to up on the brakes and for the live of me I cant figure out how in the hell the calipers go on w/ those little clamp things, so for all of you 1 ton guys /forums/images/graemlins/1zhelp.gifif you got pics that would be awsome
  2. nvrenuf
    Jan 7, 2002
    13,088
    252
    Mobile, Al.
    Re: dana 60 brakes
    All of the hardware goes on the bottom side of the caliper. The thin, flat piece of spring steel lays on top of the "U" shaped piece. With the 2 pieces together wedge them under on side of the caliper and then tap them all the way across until the inner cut out lines up with the threaded bolt hole in the bracket. At this point install the retaining bolt.
    Somebody has pics of this, I'll try to find them.
  3. nvrenuf
    Jan 7, 2002
    13,088
    252
    Mobile, Al.
    Re: dana 60 brakes
    Sorry, I never found the pics. Did you get it fixed?
  4. Bhintz
    Mar 28, 2003
    1,341
    Roswell, Ga
    Re: dana 60 brakes
    no I didnt b/c the guy I bought my spring plates from sent me one that doesnt fit so I got pissed off and havent touch it yet I will tomorrow though
  5. nvrenuf
    Jan 7, 2002
    13,088
    252
    Mobile, Al.
    Re: dana 60 brakes
    Here is a pic that might help. It's not a close up of the hardware but I think you can see enough to get you going. The long, thin piece of spring steel lays on top of the gray part (between the gray part and the caliper).
    The axle in the pic is upside down so stand on your head when you're looking at it. /forums/images/graemlins/rotfl.gif
  6. Bhintz
    Mar 28, 2003
    1,341
    Roswell, Ga
    Re: dana 60 brakes
    ok for the life of me I cant firgure out were the little w shaped metal piece goes do I even need it and dumb ? but does the bleeder nut go on the top or bottom
  7. nvrenuf
    Jan 7, 2002
    13,088
    252
    Mobile, Al.
    Re: dana 60 brakes
    Put the bleeder on top so the air will rise to it.
    What is the "W" shaped piece? Is it like the gray piece in the pic?
  8. Bhintz
    Mar 28, 2003
    1,341
    Roswell, Ga
    Re: dana 60 brakes
    figured all that out now I cant get the brake hose to seet right on the caliper when you go to bleed the brakes it leak somewhat bad were its suppose to seat and does one of the washers go under the hose or both go up top were the bolt meets the brake line
  9. nvrenuf
    Jan 7, 2002
    13,088
    252
    Mobile, Al.
    Re: dana 60 brakes
    There should be washers on both sides of the line. If you're missing one look on the old caliper, sometimes they stick together.
  10. Bhintz
    Mar 28, 2003
    1,341
    Roswell, Ga
    Re: dana 60 brakes
    so its suppose to go caliper/washer/brake line/washer/bolt??
  11. nvrenuf
    Jan 7, 2002
    13,088
    252
    Mobile, Al.
    Re: dana 60 brakes
    Yep /forums/images/graemlins/thumb.gif
  12. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    Re: dana 60 brakes
    Some aftermarket lines rub the caliper bracket at then banjo fitting (caliper side of the brake line). Mine did and it caused a good leak. A little grinder action /forums/images/graemlins/grind.gif and all was solved. Make sure you have extra copper washers as you will always find a need for more when you can't find them -> well that is how my world works at least /forums/images/graemlins/doah.gif /forums/images/graemlins/grin.gif
