Dana 60 Carrier ?
Discussion in 'The Garage' started by mtnman210, Jun 8, 2006.
  1. mtnman210
    mtnman210 1/2 ton status
    May 30, 2003
    3,880
    Northridge, Ca
    currently in my dana 60 is a 4.10 open carrier. I'm going to put in 5.13's and know I need the 4.56 up carrier. I'm also just gonna lincoln lock it. So can I just buy this empty open 4.56 and up carrier carrierhttp://www.drivetrainspecialists.com/categories/dana/dana-60/products/product-629.html
    and put the spiders from the 4.10 and down carrier I already have into the new one. Or will they be different and I need to get the new loaded carrierhttp://www.drivetrainspecialists.com/categories/dana/dana-60/products/product-713.html
  2. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    All of the iternals are the same I.E sidegears and spiders. The only difference between the carriers is the ring gear mounting flange location.
    Ira
  3. mtnman210
    May 30, 2003
    3,880
    Northridge, Ca
    cool thats what I was curious about
  4. mtnman210
    May 30, 2003
    3,880
    Northridge, Ca
    ok I just noticed that the link I used above is for 30spline and I need 35 spline which DTS doesn't seem to have. Does anybody have a part number for an empty 4.56 and up non-posi carrier or can point to a place that carries them?
  5. sandawgk5
    Oct 28, 2003
    6,881
    Not 100% but I am pretty sure the side gears are the same size just the inner diameter and spline count is different. I am almost positive the empty carriers can change out between 30 and 35 spline.
    Ira
  6. mtnman210
    May 30, 2003
    3,880
    Northridge, Ca
  7. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    Just give them a call. I'm sure they can get you what you need.
  8. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    there is always the ring gear spacer from summit (or wherever) that turns a 4.10 carrier into a 4.56 carrier.
  9. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    Empty case fits both 30 and 35 spline.
