dana 60 crossover arm
Discussion in 'The Garage' started by DERBINATOR, Mar 3, 2005.
  1. DERBINATOR
    DERBINATOR 1/2 ton status
    Jan 26, 2001
    196
    YANKTON,SD
    I was searching ebay for crossover arms and seen a couple that just had a large hole that I assume just goes over the exsisting kingpin cover.:confused: This design seems like it would be weaker then say ORD's but would it be strong enuff for the weekend warrior?
  2. jekbrown
    May 19, 2001
    45,029
    362
    Vancouver, WA, USA
    if its cold-rolled steel and sufficiently thick, its not a problem. I have run both rockstomper and WFO concepts arms with hydro and big meats... no arm-strength issues at all.
    j
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    ORD's arm has the hole too. They just weld in a cap on the top to act as the kingpin cover so you don't have to use the stock one. You can't see the hole but it is there.
    Harley
  4. DERBINATOR
    Jan 26, 2001
    196
    YANKTON,SD
    Yeah I knew the hole was there just figured the hole in the ones that the original kingpin cover is used is going to be bigger taking some of the strength. Probably not enuff to be an issue.
    Derb
