Dana 60 crossover + zero rate and axle relocate, anyone have issues?
Discussion in 'The Garage' started by sled_dog, Dec 6, 2003.
  1. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Thinking I am gonna order up some Zero Rates for the front of the K5. Gain a little more tire clearance and move my axle forward an inch for some better approach angle. Anyone had clearance issues with their crossover setup and doing this on a K5 with Dana 60?
  2. jekbrown
    May 19, 2001
    45,030
    363
    Vancouver, WA, USA
    hope not, Im doing this soon also. /forums/images/graemlins/grin.gif
    j
  3. 88K5Jimmy
    88K5Jimmy 1/2 ton status
    Jan 10, 2001
    1,323
    Tulsa OK
    Nope, did it on my dad's m1008. Moved the axle forward 1" with zero rates, D60 ORD crossover steering, WTO ram assist and 4" lift springs. It rides on 36's and we have had it flexed out really good and the draglink hasn't contacted the engine crossmember either.
  4. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    I guess my concern was more the Hysteer tie rod. Forgot to mention that. I'm gonna have the narrowed fenders with the 39.5 IROKs, should make for a really nice approach angle with moving the axle an inch forward.
  5. backyardbuilt
    backyardbuilt 1/2 ton status
    May 28, 2002
    1,301
    Olathe, Kansas
    Crossover clearance issues are not any worse than they already are. The problem is with the studs for the D60 spring plates they don't line up like stock anymore. But Azz-kickin made some degreed zero rates to fix that problem. Here is a link to that thread Link.
  6. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    I have no degree shims and no plans for any in the near future. The rig will be a totally off road vehicle so I am gonna run it as sits and see if I have any driveline issues.
  7. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    if you do ever go with a tapered shim make sure you get some top plates to correct the bolt angle...
  8. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    Yep I will be in touch if I ever decide to shim.
  9. reeser
    reeser 1/2 ton status
    Oct 8, 2001
    434
    Hayden Lake, ID
    j
    me too next week and i'm gonna have them add a few degrees of shim for my pinion angle.
