Dana 60 dually
Discussion in 'The Garage' started by clarkjw24, Jul 1, 2004.
  1. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    Whats involved with putting a 60 dually under my K5? What do I have to do to make this work?
  2. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    swap to single wheel hubs, I don;t know what else
  3. clarkjw24
    Dec 4, 2003
    3,531
    McBee, SC 29101
    Whats a hub swap run?
  4. BlueBlazer
    BlueBlazer 1/2 ton status
    Feb 15, 2001
    1,940
    Leave the hubs and run unmodified Hummer rims.
  5. clarkjw24
    Dec 4, 2003
    3,531
    McBee, SC 29101
    Will there be brake calliper issues?
  6. BlueBlazer
    Feb 15, 2001
    1,940
    Nope, at least not with the rims. I have never swapped a 60 in, my vehicles came with them so I am not sure about the brake hose changes needed. The springs and shock mounts are in the correct place. You will need the spring plates and some new ubolts of course.
  7. jac6695
    jac6695 1/2 ton status
    May 2, 2002
    1,860
    Christiansburg, VA
    4WD Factory was selling them for about $350.00/pair a while back. Cheapest I have seen.
  8. k5-newbie
    k5-newbie 1/2 ton status
    Jun 19, 2004
    399
    Huntsville, Texas
    is that for all 4 rims????
  9. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    about $350.00/pair
    k5-newbie, its for 2 /forums/images/graemlins/grin.gif
  10. BlueBlazer
    Feb 15, 2001
    1,940
    Two SRW hubs, not two Hummer rims.
  11. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    ah, I've been tricked /forums/images/graemlins/doah.gif
  12. clarkjw24
    Dec 4, 2003
    3,531
    McBee, SC 29101
    So it would prob cost about the same either way to remedy the issue. Four hummer rims two modified and two not or two new sw hubs.
  13. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    first of all problmes is that 1 ton run 40" spring pad spacing unlike your K5
    next is axle WMS width issues, and then youll need dually bed fenders and have to cut out your bedside flares larger just like on factory dually fleetside bed sides and put in reinforcement metal and bolts or weld it all, then driveshaft u joint issues, brake hose line issues and so forth.,
    good luck
  14. jac6695
    May 2, 2002
    1,860
    Christiansburg, VA
    He is talking dually Dana 60 Front . /forums/images/graemlins/doah.gif
  15. 86chevybanshee
    86chevybanshee 1/2 ton status
    May 15, 2004
    917
    beverly MA
    Edited by BadDog
    Please do not try to sell items in the wrong forum...
  16. burbBoy
    burbBoy 1/2 ton status
    Feb 4, 2002
    358
    WI
    I am running a dually front and hummer wheels. It is cheaper by far to get the wheels then the hubs. Check e-bay and look around this site and others for a deal on a pair. I payed around $50 each shipped to my door.
