dana 60 dully to sing conversion
Discussion in 'The Garage' started by andyzach, Nov 30, 2002.
  1. andyzach
    andyzach Registered Member
    Sep 2, 2002
    14
    /forums/images/graemlins/truck.gif i have a dana 60 front but its a dually. i was wandering if i can just take off the adapter and bolt a single axle wheel on. if not what do i have to do to convert it over. i dont care that the hub sticks out as far as it dose. becouse that was the only thing i can see that is differnt. any replys are greatly apreciated.
  2. burbBoy
    burbBoy 1/2 ton status
    Feb 4, 2002
    358
    WI
    You have afew options to convert it.
    1. Buy a set of single wheel hubs
    2. Have the dually hubs machined so that the outer ring can be welded close to the rotor mounting flange.
    3. Buy 2 hummer wheels for $55 each and just run the dually.
    I am thinking of going with the hummer wheels. For $55 shipped to my door its the cheapest option and beadlocks are only another $55 each!
    Brian
    82 "Burban-Like" vehicle
    D60/14FF sm465/np205 40" TSL
    with a 84 K5 removable top
  3. bigjbear
    Feb 18, 2000
    13,966
    448
    Marietta GA
    6x6 has the whole deal for 85
  4. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    So I can use a dueally axle dana 60 and get hummer rims and dont have to swap anything off the dualy axle??? /forums/images/graemlins/shocked.gif
  5. BURBIN406
    BURBIN406 Registered Member
    Nov 17, 2002
    17
    New Jersey
    Hummer rims with bead locks sounds like a PLAN. burbBoy do you have any pics of your truck? I'd really like to see it.
  6. burbBoy
    Feb 4, 2002
    358
    WI
    I will hopefully have some Monday or Tuesdat scanned in and posted. It looks quite interesting with the top off. Here is a list of what i did.
    Cut suburban from rear doors back off.
    Took 8' truck box cut 2' out of the front and welded it on.
    K5 blazer top and front part of the top sealing part from the K5 and welded the sealing area to the burbans body and clamped the top down
    I was surprized at how the body lines lined up with the box just sitting on the frame rails. Hopefully the pictures to come will show you what was done.
    Brian
  7. burbBoy
    Feb 4, 2002
    358
    WI
    I finally got atleast one picture to turn out of the burb. I will post more as i get them scanned in.
    web page
    Brian
