dana 60 ff rear vs 14 bolt ?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by K10ANDYKHAMNIC, Nov 20, 2002.
  1. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    i am going to be buying a dana 60 rear ff tomorrow out of a 3/4 ton chev has 3/54 gears and everything else is unknown . how much less strong than a 14 bolt is it ?? im ONLY refering to the axle shatfts only thats all im going to be using ...hopfully thanks -Andy
  2. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    dunno if you pplan on locking it up or not but a detroit for a 14ff is much much cheaper, as for the strength issues. They are minimal,
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    Its less strong enough that the 14FF and D70 are better in comparision than a D60 and 14FF.
    9.75" ring gear compared to 10.5" and the 1.5" shafts on the 14FF are evidence enough. The D60 uses what, 1.31" shafts?
    I've heard of more breakage on the D60 shafts than the 14FF.
    Guess if you want to spend the money on a rear axle thats weaker than the 14FF...... /forums/images/graemlins/rolleyes.gif
  4. K10ANDYKHAMNIC
    Sep 17, 2001
    1,962
    Western CO
    all im going to be using is the shafts .that is all i need to know about .
  5. K10ANDYKHAMNIC
    Sep 17, 2001
    1,962
    Western CO
    all im going to be using is the axle shafts themselves the ff ones .would a chev 3/4 ton came with a 60 or 70 ? i dont know the year . yeah the 14 FF has 1.5 shafts AT THE SPLINES THE REST IS 1.31 . the reason i am asking is cuz i may use dana 60 parts to convert my 12 bolt to 8 lug cuz it is complete and ill be able to torch off the spindles my self /forums/images/graemlins/thumb.gif
  6. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Why not just put a 14 Bolt FF back there and be done with it ?????
  7. morphed86k10
    morphed86k10 1/2 ton status
    Jun 25, 2001
    463
    Reno Nevada
    uhm, no, the whole shaft is 1.5 inches.
  8. K10ANDYKHAMNIC
    Sep 17, 2001
    1,962
    Western CO
    long story but ill try and shorten it . i like my ground clearance . i dont like the fact of how much i spent on that axle already to go and throw it away . it has the gears i want ,the locker i want . i can do the conversion cheap by myself , save the respline which is like 100$ .
    im impatient .and i like to be different . i like to go fast , i have a 305 .it has held up extremely well so far . i think thats about it .... /forums/images/graemlins/eek.gif not too short ... /forums/images/graemlins/thumb.gif
  9. K10ANDYKHAMNIC
    Sep 17, 2001
    1,962
    Western CO
    yeah sure and my 12 bolt is already 8 lug . i just measured it the other day like monday . mine neck down at least . how about yours ? /forums/images/graemlins/deal.gif
  10. K5Dan
    K5Dan 1/2 ton status
    Nov 15, 2002
    583
    Port St. Lucie,Fl
    what usually breaks is the ring and pinion
  11. K10ANDYKHAMNIC
    Sep 17, 2001
    1,962
    Western CO
    good , i wont be using that , just the axle shafts /forums/images/graemlins/smile.gif maybe ....unless the 14ff shafts will fit the d60 hubs ...anyhow if i havent busted the 12 bolt so far witha warn ff kit and alloy shafts i should be ok? holy crap cunfusion must go to bed ...
