Dana 60 frnt Dual to single hub conv. question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Liberator, Sep 7, 2004.
  1. Liberator
    Liberator 1/2 ton status
    Jul 16, 2001
    276
    Communist California
    I'm currently in the process of changing my Dana 60 dually hubs to a single. I've been trying to locate the rotors and the parts stores come up with two different part numbers. The Dana 60 is from a '78 one ton. Can anyone shed some light on this situation and tell me which rotors I need? I told them the truck is a '78 one ton 4x4 non-dually. Any input is greatly appreciated.
    Bo
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    There are only two dana 60 rotors. I don't know why I can't remember the part number but you just need single wheel rotors for a regular K30.
  3. utchev
    utchev Registered Member
    Aug 17, 2004
    91
    Salt Lake City.....
    I thought you needed single rear wheel bearing HUBS. Available at Six States, a couple of good vendors on PBB (probably here) and sometimes on e-bay. You're looking at around $200 per side plus bearings and seals.
  4. nvrenuf
    Jan 7, 2002
    13,074
    245
    Mobile, Al.
    The rotors themselves are the same from SRW to DRW. The reason for two part numbers is different size lug holes. The rotors from a DRW application will fit an SRW but you'll need to drill out the lug holes to allow the studs to go through. I can't remember the drill bit size but it's listed in the Billavista D60 Bible on Pirate.
  5. Liberator
    Jul 16, 2001
    276
    Thank you for all your help. I was scratching my head with this one. I thought the rotors should be the same. It's hard to find the right parts when the auto parts stores don't stock what I'm looking for.
    Bo
  6. nvrenuf
    Jan 7, 2002
    13,074
    245
    Mobile, Al.
    /forums/images/graemlins/thumb.gif
