Dana 60 front caliper removal?? Help, gasp, cough...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by tomseviltwin, Jun 24, 2002.
  1. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    How do you do it. Ive got hubs and spindle nuts out already. What now? Trying to get driveshafts out to replace axle joints.
  2. 4x4k20
    4x4k20 1/2 ton status
    Mar 17, 2001
    1,699
    williamson ga.30292
    There is one bolt that you have to remove it takes a allen head to do it take it out and just tap the lock out watch the top peice how it comes out the tangs go down
  3. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    4x4K20 is correct about the procedure to remove; however, I might add that taping didn't quite cover what had to be done to get mine to move. It took a BFH & BF chisle to get the job done.
  4. tomseviltwin
    Dec 23, 2001
    2,065
    Utah
    Thanks, one side came right off. The other took the BFH approach. I got the axle shafts off now. I can't believe how much crap came out on the long shaft side. How did you clean this out or did you? Thanks for advice.
  5. efilnikufecin
    efilnikufecin 1/2 ton status
    Feb 27, 2002
    168
    flint,mi
    to clean out the axle tubes i took a long piece if 3/8 round stock and threaded one end.then i put a washer(about a inch around)on the threaded end and a nut on each side of the washer to hold it in place.you could just weld a good size washer on the end of a piece of round stock.then slide it in the tube making sure you don't push any crap in the diff.and scrap out the tube.if you do this often enough you won't get a massive build up of crap in there.this is the best tool if you run in the mud alot.
