Dana 60 Front \ Chevy vs. Dodge
Discussion in 'The Garage' started by magnum4x4, May 6, 2004.
  1. magnum4x4
    magnum4x4 Registered Member
    Jan 4, 2004
    97
    Baltimore, MD
    Dana 60 Front \\ Chevy vs. Dodge
    I was wondering whats different on the dodge 60 from the chevy. Are the perches in the same spot. What about the shock mounts? What would I have to do to mount the dodge 60 under my chevy Blazer? Thanks /forums/images/graemlins/confused.gif
  2. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    Re: Dana 60 Front \\ Chevy vs. Dodge
    what year dodge? this determines a bunch of differences
    unlike chev dodge used a lot of d60s over the years
    Azkicking bushing kit will make it bolt in to your chev lift springs
  3. magnum4x4
    Jan 4, 2004
    97
    Baltimore, MD
    I am talking about an early to mid 80's dodge with a kingpin style 60 front.
  4. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    I used a 91 dodge
    if search works on this site you can find a ton of info
    several guys here used dodge 60s
    wms-wms is 2" narrower then chev
    spring perches are ~.5" wider, azkicking sells bushings that fix that
    remember to get the spring cap plates
    I use the stock 91 brake lines and they bolt to the chev frame hard line IIRC
    I may have reflared them when I moved them but do not recall doing that
    steering arms differ
  5. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    my friend with a chev 60 in his stepside, used a dodge steering arm... instead of using a steering block.
    as far the dodge 60 goes.... mj told you all you need to know... Oh wait cept for the pinion yoke go get yourself 1350 chevy d60 pinion yoke... Most likely your going to have to shorten your front driveline so tell the driveline shop to put a 1350 yoke on your front dline......
  6. bigjbear
    Feb 18, 2000
    13,970
    451
    Marietta GA
    Chevey uses a 1310 yoke, not 1350, on front axels. Including the D60.
  7. GMC
    GMC 1/2 ton status
    Jun 18, 2002
    108
    Lacey, WA
    I put a D60 out of a 1982 Dodge in my blazer. It bolted up just fine. I used everything that was already there. The brakelines worked, the driveshaft was perfect, the springs bolted up fine, the steering, everything. It was easy.
  8. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    thats why i said buy the 1350 yoke.... if you have to buy a new yoke.. and have your driveshaft worked on... why not buy the bigger yoke for the axle.. and have them put a bigger yoke on the driveshaft while they are working on it???? /forums/images/graemlins/whistling.gif
