Dana 60 front hub same for GM and Ford or no
Discussion in 'The Garage' started by 1HighK5, Apr 23, 2007.
  1. 1HighK5
    1HighK5 1/2 ton status
    Feb 7, 2005
    140
    New York
    Is the Dana 60 front hub the same for GM and Ford dana 60's?
  2. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    Lockout hub or wheel hub?? First one yes, second one no.
  3. 1HighK5
    Feb 7, 2005
    140
    New York
    Sorry about that wasn't think'n I mean the wheel hub. Just so i got it right the GM is different from the Ford so I have to find a GM one for my Dana 60
  4. 1HighK5
    Feb 7, 2005
    140
    New York
    Also what is the difference between the Ford and GM wheel hub?
  5. b454rat
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    Not sure what the diff is, maybe cause the stub and spindle are longer, the wheel hub might be longer as well??
  6. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,994
    130
    The hub itself (the big cast iron piece that has the rotor pressed onto it by the lug studs) is different between Dodge, Chevy and Ford I think. Check this article to make sure http://pirate4x4.com/tech/billavista/60_front/index.html
    They aren't much different, IIRC. They're expensive, so why change them? It'll just change your width a little bit.
  7. nvrenuf
    Jan 7, 2002
    13,079
    247
    Mobile, Al.
    The stub, spindle and bearing hub are all shorter on a Ford than Chevy or Dodge, roughly 5/8". The last few years of Dodge kingpin D60 (89-92?) are the same as a Chevy but, imo, too rare to waste time looking for.
