Dana 60 grease seal
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dysphemism, Jul 15, 2002.
  1. dysphemism
    dysphemism 1/2 ton status
    Oct 26, 2001
    667
    Fremont, CA
    So I finally got a day off from work to wrench on the 60. I put it all back together but ran into one problem. I guess it's pretty much guaranteed not to go unhitched whenever you work on your rig. well I was putting the short side rotor back on and it wouldnt go all the way in for some reason. So I took my rubber mallet and gave it some taps. Well it still wouldnt go in. So I popped it out and it turns out the spring that is in the grease seal somehow popped out. My question is, do I need a new grease seal or can I just place the spring back in place?
  2. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    if the rubber isnt torn just pop the spring back in
  3. k5blazerus
    k5blazerus 1/2 ton status
    Apr 22, 2001
    654
    Bend, OR
    If the rotor is still hard to get on use the hub nuts to put it on the rest of the way. .
    Colin
