dana 60 help
Discussion in 'The Garage' started by DirtyJim, May 24, 2006.
  1. DirtyJim
    DirtyJim 1/2 ton status
    May 4, 2005
    665
    San Diego
  2. DirtyJim
    May 4, 2005
    665
    San Diego
  3. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
  4. DirtyJim
    May 4, 2005
    665
    San Diego
  5. thedrip
    thedrip 1/2 ton status
    Dec 13, 2003
    1,129
    Chattanooga, TN
    you have to diassemble the outers, pull the axle shafts, and then the knuckle basically falls off. the axle shaft is keeping everything from moving up far enough to get over the king pin.
  6. nvrenuf
    Jan 7, 2002
    13,072
    245
    Mobile, Al.
    + the lower kin pin plate will need to be removed to create enough "slack" for it to clear the upper kin pin.
  7. DirtyJim
    May 4, 2005
    665
    San Diego
    i already removed the lower plate. can that upper kingpin be removed to slide out the whole unit?
  8. nvrenuf
    Jan 7, 2002
    13,072
    245
    Mobile, Al.
    With the lower plate removed the knuckle should tilt out on the bottom allowing you to lift it over the upper king pin.
    The upper pin can be unscrewed but it's somewhere around 600ftlbs. :eek1:
  9. DirtyJim
    May 4, 2005
    665
    San Diego
    should have ate my wheaties. thanks.
  10. K5er4Life
    K5er4Life 1/2 ton status
    Oct 16, 2002
    1,456
    Bellflower, Ca
    mmmmm...wheaties,
