Dana 60 Hi Steer Questions
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dawson444, Sep 3, 2002.
  1. dawson444
    dawson444 1/2 ton status
    Jul 5, 2000
    1,034
    Raleigh, NC
    I am looking at putting hi steer on my Dana 60. I was looking at pics on here. Why did Steve use different ends from here.[​IMG]
    to here?
    Anyone have any ideas on going with the hi steer? I am going to run Avalanch arms and the MOO crossmember. Do I need one of the spacer blocks avalanch sells or will everything clear? Anything else? Thanks!
  2. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Dawson, my oponion is don't even mess with the hysteer. I would just do crossover and get a Rockrod tierod and be done.
  3. Butch
    Butch 1/2 ton status
    Apr 26, 2000
    1,338
    Austin, TX
    You dont need the blocks they will actually hurt your clearance. Unless you abuse it in the rocks alot the Hi-steer is hard to justify. I have it on mine using the hiem joint ends. The places that I go I need the tie rod out of the way, but with the pitman arm right there you end up with your tie rod only 5" off the center line of the king pin instead of 8" which is stock. It will contribute to death wobble because of this. If I had to drive mine on the street much Hi-steer would not be an option. Steve used drag link ends on his is why they look so different. I believe they are slightly larger than regular tie rod ends.
  4. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    the pitman arm he used is from a ford application and uses a smaller tapered hole.
    so rather then retaper he used a tie rod sourced joint that fits
  5. CK5
    May 19, 1999
    21,623
    701
    CO
    Actually, I had the pitman arm retapered (larger hole) so I could use the larger K30 draglink ends, all four ends are the same right hand thread, just need to carry one spare that way.
    I also agree that for normal wheeling you really don't need the hi-steer setup.
  6. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    so has he just mixed images from different timeperiods?
  7. CK5
    May 19, 1999
    21,623
    701
    CO
    Yeah, that top pic was from a while ago.
